Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-26-2009, 11:17 AM
jackndelphine jackndelphine is offline
jackndelphine is starting off with a positive reputation.
strange carburetor noise?
Hi, I have a 74 f250 with a 67 352 and a 2150 carb. I have noticed that after driving the truck for a while and when its nice and hot, if I shut it off I hear a funny "howling" noise coming from the carb. It does it for about 5 seconds, then goes away. I rebuilt the carb and it still makes the noise. Also when I am driving it, when I have the pedal at a certain point, I can hear a lot of vacuum, I have checked for vacuum leaks, and there are none. The other question I have is, the 352 was out of a standard shift truck, mine is an auto, so I have no where to hook my tranny kickdown rod to. Does anyone have any ideas on how I can fix that, besides replacing the carb? Thanks, Jack
__________________
74 highboy, 96 explorer xlt,37 pontiac streetrod, 50 plymouth conv, 66 mustang, 00 S/C Regal,
  #2 (permalink)
Old 06-26-2009, 09:43 PM
fmc400's Avatar
fmc400 fmc400 is offline
fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE. fmc400 has a great reputation on FTE.
Hi Jack, the kickdown linkage connection on a 2150 is part of the throttle linkage. There's a mechanism that sits on the throttle shaft and rests right along with the attachment for the throttle linkage. The kickdown slips over a stud on the linkage and is secured with a clip. I'm not sure if the kickdown mechanism can be removed off a carburetor that went in a vehicle with an auto trans, or if it's pressed on to the throttle linkage. If no one else chimes in I'll try to go out in the shop and pull one. If the only way to remove the linkage would be to take the entire throttle shaft with it, I'd be hesitant to do so beacuse you'd have to remove the throttle plates to get the shaft out, which is a bad idea. The screws holding the throttle plates to the shaft are peened so that they won't work their way out, and you'd have to do something similar to re-install them which can be tricky.
I'd bet money that the vacuum leak you hear while driving, and the howling noise are related. It's probably the same leak. What we know so far is that it howls after you shut it off, which to me says it's coming from a place that would normally hold vacuum while the engine is off, but in your case it's escaping. That narrows it down - it rules out any kind of intake manifold leak. Are you sure it's not coming from the brake booster?
  #3 (permalink)
Old 06-26-2009, 09:46 PM
Old93junk's Avatar
Old93junk Old93junk is offline
Old and mean
1993 Ford F-250
Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold Old93junk is a splendid one to behold
My buddys 302 converted Ranger had a howling noise at shut down, it WAS the brake booster vac. connection.
__________________
FORCE IT!,IF IT BREAKS IT NEEDED REPLACED ANYWAY!
IF IT CANT BE FIXED WITH A HAMMER, ITS A ELECTRICAL PROBLEM!
Still bitterly clinging to guns and religion.
Dave
Oregon Assistant Chapter Leader: To join the Oregon Chapter, click HERE
  #4 (permalink)
Old 06-26-2009, 09:47 PM
That is an excellent point FMC, I think the noise could be coming from the booster. I know the booster does have that loud "hush" noise when I depress the pedal quickly, which I am pretty sure indicates that the booster is on its way out. I will have to listen a little closer tomorrow and see if I can pinpoint that noise a little better. Thanks, for the input.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
