Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #1 (permalink)
Old 06-26-2009, 11:08 AM
spikedog's Avatar
spikedog spikedog is offline
spikedog is gaining momentum as a positive member of FTE.
Torque wrench doesn't work on left hand threads??
I was installing some alloy wheel simulators on my 1982 E-350 motorhome last night. The driver's side dually has left hand threads, and I was torquing the bolts on everything to about 135 psi. I'm grunting to make that 'pop', and never got it. I mean, I was going for it - vein-in-the-forehead-popping, poop-in-your-pants max effort. No 'ping'. Do click torque wrenches not work on left hand threads? It worked fine otherwise.
__________________
“If a tie is like kissing your sister, losing is like kissing your grandmother with her teeth out.”
- George Brett -
  #2 (permalink)
Old 06-26-2009, 02:39 PM
brandon_oma#692's Avatar
brandon_oma#692 brandon_oma#692 is offline
brandon_oma#692 is starting off with a positive reputation.
I have not used any that do. Not sure what brands i used. sorry
__________________
1999.5 F_250 sd 143,000 Riffraff 6637 and CCV Excursion heated power leather seats.
  #3 (permalink)
Old 06-27-2009, 08:21 AM
ckal704's Avatar
ckal704 ckal704 is offline
ckal704 has a great reputation on FTE. ckal704 has a great reputation on FTE. ckal704 has a great reputation on FTE. ckal704 has a great reputation on FTE.
They certainly should work on LH threads if they are a reversible ratchet "micrometer" style torque wrench.
The internal pivot can go in either direction.
But, I guess if you used it for RH threads only for 20 years, the possibility of a burr of some sort internally could prevent it from clicking when tightening LH threads.
__________________
97 250 PSD Ex Cab Sd 4X4 ZF5 135k
6637 in, 4" stainless ex
cat-less
Pyro & Boost
15.6k (tx c00n!)
Fumoto drain
HPX
Marinco block heater tap
08 Diff cover
R.P. trans fluids
203 deg t-stat
Line-X
SiriusXM music & talk
Hula HP
EBPV brake
"I tried being reasonable. I didn't like it."
  #4 (permalink)
Old 06-30-2009, 09:24 AM
spikedog's Avatar
How'd you know I've had that wrench for 20 years? More like 25, actually.
__________________
- George Brett -
  #5 (permalink)
Old 07-01-2009, 07:13 AM
ckal704's Avatar
Because I am psycho- er, um, psychic.
Just a lucky guess.
__________________
cat-less
Pyro & Boost
15.6k (tx c00n!)
Fumoto drain
HPX
08 Diff cover
R.P. trans fluids
203 deg t-stat
Line-X
Hula HP
EBPV brake
  #6 (permalink)
Old 07-01-2009, 07:22 PM
Steina Steina is offline
CO River Rat
Steina is gaining momentum as a positive member of FTE. Steina is gaining momentum as a positive member of FTE.
The beam-style of torque wrench works in either direction, but is bitchy to read while torquing (hopefully you were using ft-lb and not psi).
Steve
__________________
Black 2004 Explorer XLT Sport 4.6L as my "boat hauler" for Lake Havasu/Lake Mohave runs
"I used to be wishy-washy, but now I'm not sure"
"There are 2 methods for dealing with women - neither one works"
  #7 (permalink)
Old 07-03-2009, 06:27 PM
rikfish's Avatar
rikfish rikfish is offline
rikfish is gaining momentum as a positive member of FTE.
Torque wrenches are normally calibrated for right hand threads, unless specified. I calibrated wrenches for over 20 years. Yes, most 'break' type wrenches will 'break' both directions. Look for a break action wrench that states "for left hand use". You could have the wrench calibrated at a local shop as well. Shouldn't cost too much, plus you get the security of knowing he wrench is both accurate and repeatable.
That, or depending upon $$$ available, get a dial or digital wrench. Mechanism is different than break types. Again, make sure the wrench is usable for both RH and LH. Beam wrenches are ok, but hard to read especially when you are shaking to apply that 135 lb./ft. of torque! Dial and digital will hold the peak reading for you, which is nice when used where visibility of the readout is limited.
__________________
rikfish
'03 F150 4X4 XL, 5.4 etc....
'01 E350 Ext. 15 pass., XL, SD, 5.4 etc.....
  #8 (permalink)
Old 07-06-2009, 09:45 AM
spikedog's Avatar
Thanks for the info. My internet searching has turned up several sites that say the click types won't do LH threads unless they specifically say so. It wasn't like I paid top dollar for this wrench in 1985 either. I only use it maybe twice a year when I switch to snow tires, so I think it's not getting too much wear.
What should it run me to have it calibrated? Who does it, machine shops?
Ft lbs, not psi - you are correct, Steina.
__________________
- George Brett -
  #9 (permalink)
Old 07-10-2009, 11:11 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
muscletruck7379 is starting off with a positive reputation.
my (not so often used) $400 MAC can do left or right, but according to its calibration sheet its not quite as accurate going left (I cant remember what the number were, but its accurate enough that i would feel comfy working on turbo-prop engines with that thing...)
I have only known the tool dealers themselves to take them to have them calibrated, but I don't know where they take them.
__________________
1973 f250 highboy 4x4
1984 full size bronco, megasquirted 300 on the way!
1988 f150 extended cab 4x4
1984 mercury capri, 5.0 conversion
1961 ford falcon, all stock, in family since '68
  #10 (permalink)
Old 07-10-2009, 11:31 PM
rikfish's Avatar
Look in your yellow pages under 'calibration'. Where in Wyoming are you? If in Cheyenne, you could contact Wytech and ask them. Used to be some places in Denver, but since I have moved from there I really don't know any independent labs. Cost should be around $25 or so.
Remember to ALWAYS reset your wrench to the lowest setting when not in use. The springs tend to develop a memory and this will change not only the value but accuracy as well. One last bit of info. Your wrench's accuracy changes with the setting. What I mean is the stated accuracy is for full scale. Example, your wrench has a10 to 100lb/ft, and is rated at +/- 3% fs. This means the accuracy is really +/-3 lb/ft at ANY setting. Should you use it at say, 25 lb./ft. setting, that 3lb./ft. will be +/- 12%! The suggestion is to use a torque wrench in it's upper half of it's range for best accuracy. This may not apply to newer wrenches using strain gauge technology. It has been a while since I worked in calibration. Best to look at each individual wrenches specs!
__________________
rikfish
  #11 (permalink)
Old 07-11-2009, 10:19 PM
checked the calibration sheet on mine today. at 150 ft/lbs it is 0.9 ft/lbs off on right handed and 4 ft/lbs off on the lefties...
__________________
Tags
accuracy , beam , hand , handed , left , lefthand , lh , thread , threads , torque , truck , work , wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
