Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #16 (permalink)
Old 07-06-2009, 01:55 PM
oldcoupe42 oldcoupe42 is offline
oldcoupe42 is starting off with a positive reputation.
Ford_Six, I replaced the Drag link (Twice ,1st one was too short), but where is the adjustment on the it? It looks like a solid rod with swivel ends.
Chet
  #17 (permalink)
Old 07-06-2009, 07:35 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of Ford_Six has much to be proud of
Some you increase or decrease the bends to adjust. It's a really poor system, but it's not a car either. If you are ambitious, you could cut out a chunk, thread the ends, and put in a turnbuckle. You will have to thread one end with a left-hand die though.
__________________
Jared
The government said all my vehicle were too old to be clunkers
FTE Guidelines
  #18 (permalink)
Old 07-08-2009, 08:03 PM
86bigred's Avatar
86bigred 86bigred is offline
part time
86bigred is starting off with a positive reputation.
i had this problem on my tractor and dads john deere mower.the front walking beam or axle would move back and forth .tightening the walking beam solved the problem.when i turned the steering wheel the walking beam would move forward before the wheels would turn.turn the other way,the walking beam was all the way back and tires would turn immediately.
__________________
81 f150 302 4 sp od daily driver
86 f250 460 t19 4x4
85 f150 300 t18 4x4
89 ford tempo
83 ranger 2.3 4sp
http://s469.photobucket.com/albums/rr57/86bigred/
  #19 (permalink)
Old 07-26-2009, 11:37 AM
GlennFordx4's Avatar
GlennFordx4 GlennFordx4 is online now
Who The Hell Are You
GlennFordx4 is gaining momentum as a positive member of FTE.
Quote:
Sears,Ayp tractors have this problem also and some have stops that break off or come loose,another problem they have is the frames crack where the plate for the front axle meets the frame,check around your frame at the inside of each spindle and see if it is cracked. I have seen some so bad that the only thing holding the frame together is the center bolt of the axle. I do know that when they are new the turning radius is close to the same.
__________________
Glenn
86 F150 302 efi aod with shift kit slamming stereo two tone blue and rust
93 EB bronco 5.8 all stock for now
04 jeep liberty wifes car
84 f 250HD 4x4 supercab 460 4 speed (Barney) HE'S back
  #20 (permalink)
Old 07-31-2009, 09:45 PM
weadjust weadjust is offline
weadjust is starting off with a positive reputation.
I talked to a lawnmower repair guy and he said 90% of the time steering problems on a craftsman lawnmower is the steering shaft support. Its a plastic part that keeps the steering wheel shaft in correct contact with the sector gear. He said he keeps them in stock at all times. The cost of the part was $6 bucks and change. Link to part #160395.
http://www.jackssmallengines.com/sea...ormat=searchdb
  #21 (permalink)
Old 08-02-2009, 09:16 AM
I stock them to,but when they go your steering wheel usually skips when you try and make a sharp turn.
__________________
Glenn
Tags
assembly , axle , bent , craftsman , ctaftsmansteeringframe , forum , front , lawn , left , mower , parts , rod , steering , tractor , turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
