Did some maintenance and mods (Pics)
Old 06-26-2009, 03:46 AM
Visseroth's Avatar
Visseroth
Visseroth is offline
OK.... So I'm finally sitting in front of my computer now editing some pictures and posting while I wait for my IDM to dry after replacing the 75.8K resistor with a 74.9K resistor and I'm glad to have this much of the maintenance done though I found out today that I need new batteries. Mine are about shot.
Anyhow, here are the pictures.......
While disconnecting the driver's side harness from the UVCH I found that I had a wire on the verge of breaking. So much so that it broke off when I was disconnecting it. I later fixed it by tinning the wire and tinning the contact lead that goes inside the plug and soldering them together. It worked quite well and now there's one less thing to break
I also completed the quarter mod so that I might not have the horrible experience of being stuck on the side of the road some where and torqued my rocker arms and injectors. Well I tightened them since I didn't have any torquing tools. I was extremely gentle with the injectors and just snugged the rockers.
Here is the passenger side after the IC tube was removed
Here's the driver's side valve cover back on and the CCV mod going in (Thanks Clay)
Here's a top side view after cleaning the pipes and reinstalling them
Here a view of the HPX installed after I got the IC pipes back in. I forgot to take pics before I put the pipes in.
Here's a pic of the IDM after the 75K mod had been done
Here's the IDM waiting to dry and a C clamp holding the lid on to ensure a good seal
And now... A job well done.......................
Old 06-26-2009, 05:51 AM
F350-6's Avatar
F350-6
F350-6 is offline
Looks good, but you missed the quarter with your circle
You did grind the top down so it didn't touch the valve cover, right? In the pic it looks like the full quarter is in there.
Old 06-26-2009, 06:51 AM
danskool's Avatar
danskool
danskool is offline
Go Bills !
Nice pictures.. Good work..
Old 06-26-2009, 07:00 AM
greedy737's Avatar
greedy737
greedy737 is offline
Nice work!! How hard was it to get the valve covers off and where any of the inj. or rocker bolts loose?
Old 06-26-2009, 07:30 AM
brandon_oma#692's Avatar
brandon_oma#692
brandon_oma#692 is offline
Quater mod?
Old 06-26-2009, 07:33 AM
Texas Outlaw's Avatar
Texas Outlaw
Texas Outlaw is offline
Not a liberal...
Originally Posted by brandon_oma#692
Quater mod?
The quarter mod is also called the fifty cent mod. A quarter is used in the UVCH connector so that it cannot come unclipped. When these work loose, the end result if a badly misfiring motor.
Old 06-26-2009, 07:34 AM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
Good eye. I saw the circle in the wrong spot but didn't catch the quarter that needs to be cut down.
Old 06-26-2009, 07:38 AM
Ford79's Avatar
Ford79
Ford79 is offline
Quater mod?
As Scott said, it's AKA the 50 cent mod. Here's a link with pics https://www.ford-trucks.com/forums/8...ml#post6900483
Old 06-26-2009, 07:58 AM
03_PSD's Avatar
03_PSD
03_PSD is offline
Great job, nice pics!
Old 06-26-2009, 08:31 AM
00Dave's Avatar
00Dave
00Dave is offline
Would it be possible to use knockouts from an electrical box instead of quarters? Anyone try that yet?
Old 06-26-2009, 08:57 AM
big poppa's Avatar
big poppa
big poppa is offline
Another job I have to do, great pics and info..
Old 06-26-2009, 09:04 AM
miller_feed's Avatar
miller_feed
miller_feed is offline
Hook it, I'll pull it.
Looks like you did a good job. Congrats.
Looks like he did grind it down, because it don't look like it sticks out to the gasket.
The thickness of the quarter has something to do with keeping it in place. The quarter is just right.
Don't forget, you have to put one in with the head showing and the other with tails showing.
Old 06-26-2009, 09:05 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
Don't see why not... Cheapskate.
Old 06-26-2009, 09:06 AM
superduty4x4's Avatar
superduty4x4
superduty4x4 is offline
Looks like you de-foiled your driver's side IC pipe (yes I know he has an early 99, I was confuddled when I met him and saw the foil on the drivers side).
You should have called me, I would have loaned you my torque wrench for the rockers and injectors
Old 06-26-2009, 09:09 AM
big poppa's Avatar
big poppa
That cracked me up..maybe if you doubled them up Might just work
Quick Reply: Did some maintenance and mods (Pics)
