Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #61 (permalink)
Old 07-15-2009, 01:01 PM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
The newer autos like 4R70 and 4r100 use a locking torque converter. I had a factory tech valve body in my 4r100 and took it out because it didn't do anything to make the tq lockup quicker and firmer. I then ran a tuner (custom tune) in conjunction with my VB but had trouble to get both in sync with eachother and peform the way I wanted it. (got a bump ocassionally) In stock form the TQ lockup strategy just feels like crap and is slow too boot. Making the lockup quicker and firmer reduces trans temps and helps the trans to last longer. Not to mention it performs better also. I'm going to go to a local trans shop thats done work for me in the past and see what they can do for me mechanically. I think I need a "shift kit" along with an on/off lockup valve but have to ask them about it. I'll still use the tuner just keep the trans set to stock parameters. I'm not a trans expert or anything just saying from experiences I've had with mine and trying to correct it.
  #62 (permalink)
Old 07-15-2009, 09:48 PM
79 f-150 guy's Avatar
79 f-150 guy 79 f-150 guy is offline
79 f-150 guy is starting off with a positive reputation.
so i can correct it with a tuner or will i need a diferant converter??
however i just heard on the mustang forum that with some work you can make a c4 full auto behind a 4.6... you need a universal lokar cable like "havi" mentioned and you can make that work by adapting it to the spot on the throttle body for the cruise controle.. i have to keep looking and varifie i can do that, if so i mite be able to use my c4 afterall. but on another hand having overdrive would be a plus......
  #63 (permalink)
Old 07-15-2009, 10:29 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
The TC lockup is controlled by the PCM, so a tune should be able to make that happen faster. As for "firmer", not entirely sure, but I'm sure it's possible. I know with my '96 t-bird 4.6 w/Superchips, shifts were firmer (upped the pressure during the shifts only) and the TC lockup was more noticeable, but then I had a 3.73 rear in that thing too.
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #64 (permalink)
Old 07-16-2009, 05:19 AM
kaboom10's Avatar
kaboom10 kaboom10 is offline
2002 Ford F-150
kaboom10 is starting off with a positive reputation.
I've changed all my shift schedules and TC lockups with my PRP tuning program because I switched to a 4.88 rear gear. If you do use the 4R70 put a better TC in it.
  #65 (permalink)
Old 07-16-2009, 05:39 AM
lew52's Avatar
lew52 lew52 is online now
lew52 is gaining momentum as a positive member of FTE.
If you use the 4R70W & want quick , hard , tire spining shifts use the B&M street / strip shift kit . If you use a tuner or have a chip burned for it you can adjust all the up & down shifts , line press , adjust the TC . I use the stock TC & the stall is 1900 rpm... Lew
  #66 (permalink)
Old 07-16-2009, 11:11 PM
well i will run a shift kit.. anyone know where i can find a good 4r70w.. i cant find one for sale resonalble in my area...
  #67 (permalink)
Old 07-21-2009, 11:18 PM
ok, after a week of asking dum questions and checking the four corners of the county i finally think things are ookin up.. i found a guy with a rearended 1992 lincoln t-car with a good running 4.6 and a good tranny for 200.00. i want to go get it but i think it mite have an AODE in it not a 4R70W.. is there any way to tell the diferance easy. thanks
  #68 (permalink)
Old 07-22-2009, 11:53 AM
Krewat's Avatar
Found this, and about the only external difference is the extension housing and seal diameter?
http://www.becontrols.com/ourfaqs/aodefaq_1.htm
Checked some things, and that might even be just an AOD, not an AODE. See if it's got the big electrical connector on it.
Would a non-electronic AOD be better for your application if it was built right?
__________________
  #69 (permalink)
Old 07-22-2009, 12:43 PM
dkf's Avatar
dkf dkf is offline
The AODE and 4R70W are beefed up and an overal improvement over the AOD so I'd say the AODE would be better than the AOD. Plus with the AODE and 4R70W you can use a locking torque converter. An AOD should probably be torn down and built up a little for the 4.6l.
  #70 (permalink)
Old 07-22-2009, 01:34 PM
kaboom10's Avatar
2002 Ford F-150
The 4R70 will take 500 ponies. They couldn't let the puny trans up against a blown 4.6.
__________________
2002 F-150 5.4L 4wd
Baer rotors EGR Carbon Kevlar pads-Kenwood stereo-IAS shocks
Livewire PRP tuned w/wideband O2-4.88 gears and Trutrac carrier-B.F.Goodrich Rugged Trail
http://i48.photobucket.com/albums/f2...0/100_0291.jpg
  #71 (permalink)
Old 07-22-2009, 03:14 PM
lew52's Avatar
If you do use an AOD , swap in the gear sets from a 4R70W into it will help alot , stronger & better gearing . Are you using a computer that will run an electronic controled trans ???? Lew
  #72 (permalink)
Old 07-22-2009, 04:31 PM
i got my factory 93 lincoln mark viii computer wich ran a 4r70w but i cant be sure it will run an aode??
  #73 (permalink)
Old 07-22-2009, 05:04 PM
lew52's Avatar
That will work.... Go with the 4R if you can ...
  #74 (permalink)
Old 07-22-2009, 05:07 PM
thats what i want to run and i have one that needs rebuilt but rebuilding these is so expensive and i cant figure ou how to wire it up....
  #75 (permalink)
Old 07-22-2009, 05:40 PM
kaboom10's Avatar
2002 Ford F-150
See if you can find a wiring diagram online.
__________________
2002 F-150 5.4L 4wd
Tags
46 , 50 , cam , dohc , dual , f150 , f250 , ford , harness , modification , motor , overhead , swap , swapping , wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
