Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #46 (permalink)
Old 07-07-2009, 05:50 PM
79 f-150 guy's Avatar
79 f-150 guy 79 f-150 guy is offline
79 f-150 guy is starting off with a positive reputation.
well, i'm gonna go with a good sealer to keep it from rusting. or maybe i'll just rustoleam it, you can thin that stuff down and spray it thru a gun.. looks good too, but lots of orange peel.
  #47 (permalink)
Old 07-08-2009, 12:22 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
Black primer with clear satin poly...
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #48 (permalink)
Old 07-08-2009, 02:12 PM
ya, thats what its called "clear satin poly".. couldnt remember what the top coat is called on a flat paint job... thanks
  #49 (permalink)
Old 07-10-2009, 08:56 PM
ok, finaly makin some leadway... i found a used c4 bellhousing for 250.00 so i'm trying to buy that rite now.. today i cleaned it up some more and started painting the fromnt of the frame. my cab will be here on monday so i will be putting that on as soon as i get new mounts..... once i get that bellhoung and the cab things will start coming together fast, i hate this slow pace... but what ya gonna do when your waiting on parts. thanks
  #50 (permalink)
Old 07-10-2009, 10:21 PM
havi's Avatar
havi havi is offline
Collector of rust
havi is gaining momentum as a positive member of FTE. havi is gaining momentum as a positive member of FTE.
Subscribing. Pondering a 5.4 for my '78 4x4, and this may help. Keep going!!
__________________
The going, the journey, should be the objective of a trip in a built old Ford, the destination always secondary.
  #51 (permalink)
Old 07-10-2009, 10:35 PM
go for it, the 5.4 is a bit biggger so you mite run into more clearance problems than i did but that would be an awsome project. thanks
  #52 (permalink)
Old 07-11-2009, 07:18 AM
kaboom10's Avatar
kaboom10 kaboom10 is offline
2002 Ford F-150
kaboom10 is starting off with a positive reputation.
Quote:
The 5.4L is a lot more torque and I have the rubber streaks in the driveway to prove it. Just gear it right after it's in.
__________________
2002 F-150 5.4L 4wd
Baer rotors EGR Carbon Kevlar pads-Kenwood stereo-IAS shocks
Livewire PRP tuned w/wideband O2-4.88 gears and Trutrac carrier-B.F.Goodrich Rugged Trail
http://i48.photobucket.com/albums/f2...0/100_0291.jpg
  #53 (permalink)
Old 07-12-2009, 11:11 PM
ok cab should be here tomarrow, i can hardly wait.. also just heard from the guy with the belklhousing, gonna be buying that as soon as we work out a deal...
today i pulled the engine back out and cleaned the frae so i can paint it.. still gota drill the holes to mount the frame mounts.. i tried but these frames are tuff, burned up 3 bits trying to drill the holes... mite need a diamond tipped bit, lol
anyway i'll get some more pics on here tomarrow or teusday. thanks
  #54 (permalink)
Old 07-13-2009, 09:45 AM
dkf's Avatar
dkf dkf is offline
dkf has a good reputation on FTE. dkf has a good reputation on FTE. dkf has a good reputation on FTE.
Definatly a sweet project and should haul ass when done. I'm subscribed to this thread for shure. If you need any carbide bits to get through the frame rail you can get some fast from www.mcmaster.com you don't need an account and they have a big warehouse in NJ so you'll get the stuff next day.
  #55 (permalink)
Old 07-13-2009, 12:11 PM
thanks for the tip, i'll have to check into them later today....
  #56 (permalink)
Old 07-15-2009, 12:14 AM
i got good news and bad news..
the good, well i got my cab yesterday.. looks good, i'm preping it for instale rite now....
the bad, it looks like using a c4 auto is out. i geuss they make all the parts but a kickdown cable, becouse it is desined for people that are doing a c4 with manual valve body.. i dont want that, i i geuss i am gonna have to figure out how to hook up the wiring for the 4r70w that i got.. i was trying to get around the wiring invalved in that. thats why i was gonna use the c4... so i'm on th lookout for some wiring info for 4r70w tranny's if anyone knows where i can get a layout... thanks
  #57 (permalink)
Old 07-15-2009, 05:02 AM
kaboom10's Avatar
2002 Ford F-150
The 4R70 is a good trans. Just needs a shift kit. The harness should just hook right up.
  #58 (permalink)
Old 07-15-2009, 08:39 AM
dkf's Avatar
dkf dkf is offline
The TQ will be loose also and take a while to lockup. I'd take care of the converter lockup also if your going to put a "shift kit" in it.
  #59 (permalink)
Old 07-15-2009, 11:43 AM
havi's Avatar
Collector of rust
Did you try Lokar for the cable?
__________________
  #60 (permalink)
Old 07-15-2009, 12:27 PM
yes i tried them, the best they had was a universale kit for a c4, but i cant find one that i can make work with my throttle body injection...
also,dkf.. what do you mean by torgue converter lockup and how can i cure that.. thanks
Tags
46 , 50 , cam , dohc , dual , f150 , f250 , ford , harness , modification , motor , overhead , swap , swapping , wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
