Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #151 (permalink)
Old 08-28-2009, 09:04 PM
scott9050 scott9050 is offline
scott9050 is starting off with a positive reputation.
Quote:
Originally Posted by Krewat View Post
Well, for starters, the Mustang Cobra motor is an aluminum block, the Lincoln is cast iron.
No. The Mark VIII engine is a Teksid aluminum block and was so from 93-98.
__________________
1993 aerostar xlt extended 3.0
1990 AOD 5.0 mustang
best old time 13.65 at 104.57
  #152 (permalink)
Old 08-28-2009, 09:48 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
Wow, I always thought the Mark VIII block was cast iron.
Maybe I'm thinking of the Navigator's 5.4 4-valver?
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #153 (permalink)
Old 08-28-2009, 10:13 PM
bulletsneverlie bulletsneverlie is offline
bulletsneverlie is starting off with a positive reputation.
Sure thing. Thanks for the info. The last message I sent about it was a PM.
Stupid Questions: 79 guy, You have power steering, right? I was just wondering, as you said there is little room around the steering gear.
What's the idea for the Drive shaft? (custom, or a particular length?)
Are you gonna stick with the 9 inch Rear? What gears do you think? The Lincoln had around 3.77, right (from memory, sorry if it's wrong)
What are you gonna do about the Cluster? (Speedo, guages)
Will the lack of systems common on the Lincoln make the computer go loopy? (Lincoln has power everything, air ride system, climate, safety airbags, etc; I want to use the factory computer to save $, but run my old school '74 heater box, old school exterior lighting, etc )
  #154 (permalink)
Old 08-28-2009, 10:26 PM
06silvercrew's Avatar
06silvercrew 06silvercrew is offline
06silvercrew is gaining momentum as a positive member of FTE. 06silvercrew is gaining momentum as a positive member of FTE.
The price difference from the Mark vs. cobra engine is the heads. The cobra has a FAR superior head design. They are both teksid blocks.
__________________
God is Great, Beer is good, people are crazy
'06 F250 PSD XLT, CC, SB, 4x4, SCT custom tune from eric, ARP studs, autometer gauges, 4'' MBRP turbo back, AFE stg II, EGR delete, Zoodad, Chrome step bars, '08 mirrors, viper Alarm, Rough Country 8'' Lift, MT MTZ 36-15.50-20, 20X10 Motometals.
ASE + GM Master Tech+ L1
  #155 (permalink)
Old 08-28-2009, 10:36 PM
79 f-150 guy's Avatar
79 f-150 guy 79 f-150 guy is offline
79 f-150 guy is starting off with a positive reputation.
yes i have power steering but that clears fine. it is tight around the steering box and header, becouse the sterring box is on the drivers frame rail rite by the new location of the header.
as for a drive shaft you will need a custom one made becouse it is shorter, your truck should have a split two peice one like mine anyway so have a one peice one made, it wont cost you as much power that way.
i'm stikin with my 9" rear and adding 430:1 gears, i did the math and asked a few guys with stangs. with the 4.6 high rever and a 4speed auto and no imrc plates you need at least 430's to keep the rpm's up so it makes power.
as for the cluster, i am using my factory one and wiring it up to work with the 4.6 sencers.
as for wiring, save yourself the heartach and spend the $900.00 on the custom sonvertion harness, i have spent a ton of time trying to master the lincoln harness, but hay it has not started yet. though i am sure it will run on my system, it was a pain in the ass to play with and i needed ewvery harness from the car, then i had to weed out all the stuff i didnt need and once it is done, i will need to spend 700.00 on a custom tune so the engine runs rite with all the lincoln stuff missing. thanks
__________________
1979 F-150 2WD WITH 4.6 COBRA SWAP..
1987 MUSTANG GT T-TOP
1968 CORONET 4DR "DAILY DRIVER"
  #156 (permalink)
Old 08-28-2009, 10:38 PM
Quote:
from what i gatherd the headds are the same from a 93-up mark viii as 96-98 cobra heads. they are both "B" style heads, it was not till 99 that the cobra got the better flowing "C" heads. however the cams are diferant, please correct me if you are sure i'm wrong. but thats what i have read and heard. thanks
__________________
  #157 (permalink)
Old 08-28-2009, 10:39 PM
For the price difference, I can certainly deal with it. I'm pretty sure it will be night and day compared to an old 302.
  #158 (permalink)
Old 08-28-2009, 10:45 PM
ya i got ya, thats the same way i felt. i could have built a gas sucking, always under the hood tunning it 450hp 460 or i figured i could make better mpg's run cleaner and not need to constantly play with it and still have a good solid 350-375hp and just run my 4.6.. i was told the 302's in these years only make about 100hp at the tires.. so big improvment adding the 4.6!!
__________________
  #159 (permalink)
Old 08-28-2009, 10:55 PM
havi's Avatar
havi havi is online now
Collector of rust
havi is gaining momentum as a positive member of FTE. havi is gaining momentum as a positive member of FTE.
Keep going!! Keep going!!!
__________________
The going, the journey, should be the objective of a trip in a built old Ford, the destination always secondary.
  #160 (permalink)
Old 08-28-2009, 10:58 PM
Quote:
LOL!!! will do, gota get it in a garage before winter comes in....
__________________
  #161 (permalink)
Old 08-28-2009, 11:01 PM
one other thing for ya,
you will need a power steering pump from an early 90's crown victoria "one with a steering box yet". becouse the rack and pinion pump from the mark viii wont work with a steering box..
__________________
  #162 (permalink)
Old 08-28-2009, 11:32 PM
Have you done any research on whether the Lincoln motor will run with a Mustang Manual Trans?
I usually drive mtx, and I've done atx-mtx swaps on Jap cars before, rigged wiring and swapped whole harnesses. That's what pulled me in. I'm a fiend for cams, the more, the merrier.
This was going to be my simple toy, but the facts of high gas prices, and low MPG for mediocre HP got me moving in this direction. My original idea was to sell a few old engines and trans' to get the cash to go Efi, then I started down this path. I do want to see you successful before I begin though. Wiring isn't usually a problem for me.
I'd say ground faults, or ATx safety switches are probably your problem. You need to test grounds with a voltage tester, not just continuity. A partial ground won't do with a computer. I'd run the harness as though your truck was a Mark VIII. Use the ignition switch, use the cluster (for now), heck, rig up the darn crash sensors, everything you can. Most of the time tuners run without nearly everything though. How did you set up the Fuel injection? Is the Fuel Pump in the tank? It usually is on all the Jap cars I've worked on.
How far are you?
1. Do you get it to crank when you turn the key? 2. Are you getting fuel? (listen for the Fuel Pump whir, or pull the line off the Fuel filter to check for pressure, it should spray out, watch your eyes) 3. Are you getting spark? (Crank the motor and spray Carb Starter in the intake. If you get ignition, you got spark) Heck, you can get a pin-out diagram of the ECU and a tester and check the grounds, you can use jumper wires to run the FP to test it, things like that.
That's all there is to Fixing a Jap style motor (tuner). Old school guys tell me it's hard, I say they're impatient.
Do you happen to have a digital copy of the Mark VIII shop manual? If you do, I'd like a copy, so I can better picture everything in my head.
I really would like to run an MTX. No muss, no fuss. Heck, I haven't driven an automatic on the highway in 10 years.
I hope I can help, I'm not a licensed mechanic, just a college drop-out mechanical designer.
  #163 (permalink)
Old 08-29-2009, 05:53 AM
kaboom10's Avatar
kaboom10 kaboom10 is offline
2002 Ford F-150
kaboom10 is starting off with a positive reputation.
Finally got a chance to catch up. Just got back from the hospital. Needed a knee. My projects are on hold. Happy B'day dude. I just had me one but a long way from 18. Sounds like you are progressing well. Good luck.
__________________
2002 F-150 5.4L 4wd
Baer rotors EGR Carbon Kevlar pads-Kenwood stereo-IAS shocks
Livewire PRP tuned w/wideband O2-4.88 gears and Trutrac carrier-B.F.Goodrich Rugged Trail
http://i48.photobucket.com/albums/f2...0/100_0291.jpg
  #164 (permalink)
Old 09-01-2009, 03:53 PM
ok, i still have not mounted the cab, after thinking it over i decided i'll slow down a bit and make a smooth firewall for it first. reason being is the cab i got is an a/c cab so it has a huge whole in it. i was gonna just bolt a plate in over it but a think it makes more sence to take it ove tomy buddy's shop and have him weld in a flat smooth firwall out of heavier gauge steel and then rather than paint the ening bay black i'll paint itto match the truck.. wich will be paint "dove gray" i decided, it's kinda like a shiny primer color.
the way i look at it is if i'm spending the money to build it and want it done the best way i know how, then i better just take my time and do it rite.. "BUT YA NEVER KNOW WITH ME, I COULD CHANGE MY MIND AND MOUNT IT TONIGHT"....LOL
__________________
  #165 (permalink)
Old 09-01-2009, 09:25 PM
I've got the same hole in my firewall. I'm gonna put in a plate, and mount my '74 heater box. It's simple, two operating cables. You need defrost around here.
Tags
46 , 50 , cam , dohc , dual , f150 , f250 , ford , harness , modification , motor , overhead , swap , swapping , wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
