Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > 335 Series- 5.8/351M, 6.6/400, 351 Cleveland
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-25-2009, 08:04 PM
1977 F250 4x4 1977 F250 4x4 is offline
1977 F250 4x4 is starting off with a positive reputation.
No Start
1977.5 400 2bbl C6 no air. My truck has been running fine until today.
Turn the key and nothing or just some solenoid chatter with the lights on but kinda dim or they don't come on at all. Hmmmm... Ok, Clean battery cable connections check the solenoid bolts are tight the ground strap from engine to the cab is there and in decent shape. The starter itself is about two years old from Napa. Still no luck. Allright, the battery is five years old Farm Fleet pull the caps and discover all the cells are about dry add some water put the charger on it.
Still no luck but a new observation when I turn on the parking lights I see power with a test light at the negative battery post none at the positive post. Parking light switch in the off position and I have power at the positive post not at the negative post.
The voltage regulator looks to perhaps be the original. Suggestions appreciated.
  #2 (permalink)
Old 06-25-2009, 09:21 PM
grclark351 grclark351 is offline
grclark351 is starting off with a positive reputation.
...dry 5 yr old battery.... get a new battery.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
