Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-25-2009, 06:56 PM
david00f150 david00f150 is offline
david00f150 is starting off with a positive reputation.
302 timing
Everyone says that the timing of a 302 should be 10 degrees, and you can bump it up to 12 degrees or until it pings if you run higher octane gas. Well my motor is running good at 12 degrees on 87 octane.
Well what exactly is pinging b/c no one ever explains it, and does anyone have any experience with running your motor advanced at 12 degrees or higher?
__________________
1977 Bronco 5.0L V8 C4 Tranny
1987 5.0L V8 F150 Custom C6 Tranny
2009 Explorer
  #2 (permalink)
Old 06-25-2009, 07:39 PM
393STROKER's Avatar
393STROKER 393STROKER is offline
393STROKER is starting off with a positive reputation.
The pinging is the ratteling sound coming from the pistons under load when your using too low of octane or your timimg is too far advanced . Leave it @ 12 if it`s running good.
  #3 (permalink)
Old 06-26-2009, 12:57 PM
daveengelson's Avatar
daveengelson daveengelson is offline
daveengelson is gaining momentum as a positive member of FTE. daveengelson is gaining momentum as a positive member of FTE.
Novice, fiddling with 'timing' and 'carb' adjustment. Understand, or have been told, it's best to set timing as far advanced as possible without the engine pinging. Set the timing on the 302 at around 12 btc for quite some time and found it occasionally backfired thru exhaust and truck bucked coming to a stop. Recently adjusted timing to around 8 btc and seems to run better. Still fiddling, guess it's a matter of finding 'g' spot somewhere in the 8-12 range.
__________________
'problem with engaging in useless activity is never knowing when your done'
Never engage in a battle of wits half armed!
65F100, 302ci, T18, swb, flareside,front disc. PS, Duraspark Ign.
65F100, 390ci, 3sp.OD, lwb, styleside, front disc., Duraspark Ign.
dave
  #4 (permalink)
Old 06-26-2009, 02:04 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
timing a carb motor and timing an efi motor are different.
__________________
94 XLT 5.8/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG MT's
4.88 gears/Aussie Front/rear open
JBA shorty, Custom Y pipe,3" exhaust
http://www.supermotors.org/registry/...il.php?id=4158
  #5 (permalink)
Old 06-28-2009, 01:45 AM
DasCheckers's Avatar
DasCheckers DasCheckers is offline
Montana, fool.
1993 Ford F-150
DasCheckers has a good reputation on FTE. DasCheckers has a good reputation on FTE.
Are you EFI or carb?
__________________
Stoney | Montana Chapter Leader of FTE
Live in Montana? Come join The Montana Chapter,
1993 Ford F150 XLT 4x4 5.0 5spd with a Fresh Rebuild
Write your congressman!
  #6 (permalink)
Old 06-28-2009, 02:18 PM
Nathan Plemons Nathan Plemons is offline
1995 Ford F-150
My Garage
Nathan Plemons is starting off with a positive reputation.
You can ask the question of what base timing should be and you'll get a million different answers. I know because I asked and did get a million different answers. I've found a few printed sources, however, that say the base timing should be 6* BTDC. I set my truck to this yesterday, it was way off from this to start with. I cannot notice any difference better or worse.
In my case I'm just trying to get everything set the way it's supposed to before I go trying to tweak it.
  #7 (permalink)
Old 06-28-2009, 02:31 PM
Montana, fool.
1993 Ford F-150
If you have a 302, it's 6* BTDC, if you have a 5.0 it's 10* BTDC.
I have an EFI 5.0 and it's running at about 15* BTDC.
__________________
  #8 (permalink)
Old 06-28-2009, 03:47 PM
daddy172005's Avatar
daddy172005 daddy172005 is offline
daddy172005 is starting off with a positive reputation.
A 302 is a 5.0
__________________
Mason
74 F100 302
  #9 (permalink)
Old 06-28-2009, 03:55 PM
1995 Ford F-150
My Garage
Quote:
Originally Posted by daddy172005 View Post
A 302 is a 5.0
Although technically correct, there could still be a distinction. The Ford 300 six cylinder is also called the 4.9L. Ford made the switch in nomenclature at some point, I'm not exactly sure when or why. It could very well be that technically, when referred to as a 302, it means an earlier carb'd engine, whereas a 5.0 refers to a newer fuel injected engine, even though the block is the same.
That's my guess as to what he meant anyway.
  #10 (permalink)
Old 06-28-2009, 06:28 PM
My motor was EFI and when I rebuilt it i swapped to a holley 650 double pumper
__________________
2009 Explorer
  #11 (permalink)
Old 06-28-2009, 09:11 PM
gearhed1971's Avatar
gearhed1971 gearhed1971 is offline
1973 Ford F-100
gearhed1971 is starting off with a positive reputation.
Engines were set at 6* for emissions standards.Any old hot rodder who set timing "by ear" can tell you the hotter the timing,the better the response,as long as its not too hot.When timing is too hot,the engine will want to crank over hard when hot and ping. http://www.type2.com/library/engineg/ping.htm
__________________
gearhed1971
1973 f100-390 4wd
1963 falcon-under construction
1951chebby special deluxe(for sale)-SOLD!!!
daily beater poontang sunfire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
