Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-25-2009, 05:14 PM
Rolando14 Rolando14 is offline
Rolando14 is starting off with a positive reputation.
1988 ZF transmission
hey guys, this is my first post on the site.
seems like the neat/informative place to be...
i have a 1988 F350 dump body, it has a zf s542 5 speed manual that is really not in good shape. All gears do not sound good at all, the only gear that sounds exceptional compared to the rest is 4th because I don't think it was used in the higher gears.
i got the truck for $1,000 and it only has 33,300 miles on it. it was owned by a local cemetery. (lucky me)
am i better off finding another ZF, or can i get away with rebuilding? i've heard the c6 won't work out because the truck has a pto... any response would be appreciated
thanks
  #2 (permalink)
Old 06-25-2009, 07:02 PM
Sycostang67's Avatar
Sycostang67 Sycostang67 is offline
1993 Ford F-250
Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE. Sycostang67 has a good reputation on FTE.
You can usually get a used ZF for around $6-800. It would be the easiest thing to do.
__________________
http://www.ford-trucks.com/user_gallery/tmp/159/159207.520.390
1993 F-250 HD XLT Lariat SC 4X4 7.3/5spd ATS Turbo 173hp/335tq
1986 F-250 HD XLT Lariat SC 4X4 460/C6
1985 F-250 HD XLT Lariat SC 4X4 460/5spd
1974 F-250 HD 2wd-360/C6
1967 Ford Mustang-351W/4spd
  #3 (permalink)
Old 06-25-2009, 08:32 PM
ArdWrknTrk's Avatar
ArdWrknTrk ArdWrknTrk is offline
<--Dog is my Co-pilot
ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold
Welcome to the FTE forums Rolando!
I had a 1960's Dodge dump with a slant 6 that came from a cemetery.
It had never been registered and had similar mileage.
The front end was shot from all the low speed turning it did.
On topic: The ZF 5-speed is a desirable gearbox.
Here is the troubleshooting guide link: http://www.zf.com/na/content/en/impo...ing_Guide.html
There are also the exploded view: http://www.zf.com/na/content/media/i...2_Exploded.pdf
And data sheet: http://www.zf.com/na/content/media/i...2datasheet.pdf
Without looking inside I don't think anyone could tell you whether you're better off rebuilding or exchanging it.
If you can find a bellhousing (you don't say which engine displacement) you do have the option of a Borg Warner T-19 4 speed which has PTO's on both sides.
These are pretty bulletproof and more common.
Hope this helps.
__________________
Jim
'87 F-250 4V 460, T19, 4x4, 4.10 sterling 10.25" - Lil' Red
http://i246.photobucket.com/albums/gg117/donjamer/FTE%20Pics/blumax500-1-1.jpgFTE Fraternity of Blue Max
  #4 (permalink)
Old 06-25-2009, 10:01 PM
for that price, i just don't feel like i'm doing myself any favors... i found a trans for $200 last week but it turned out to be 4wd =(
Hope this helps.
Thanks ArdWrknTrk, that was all more than helpful. I am going to crack this trans open and take a peek. I'll take pictures when I do. Sorry for failing to mention it is a 351, v8. I am unsure if it is a windsor or cleveland, or if that's irrelvant.
I am going to check out these links right now. thanks!
  #5 (permalink)
Old 06-25-2009, 10:31 PM
ArdWrknTrk's Avatar
Attn: FYI, per the troubleshooting guide.
"Check if there are any noise changes in a particular gear, i.e., 4th gear. In 4th gear the countershaft is not under load."
__________________
Jim
  #6 (permalink)
Old 06-25-2009, 10:33 PM
alxsnmr alxsnmr is offline
1991 Ford Bronco
alxsnmr is gaining momentum as a positive member of FTE.
The motor is a 351 windsor, the cleveland and its offshoots havent been produced in the US since the seventies. Australia saw it live longer though but that is a different topic. If you need another tranny to replace it, that shouldn't be that big a deal to find a 2wd 351 tranny, just a little more looking is all.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, custom trimmed rear fenders finished in rust.
2009 Fusion SE 2.3L 5spd Red/black cloth n leather
  #7 (permalink)
Old 06-25-2009, 10:41 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is starting off with a positive reputation.
i would spend a grand and have it rebuilt. Buying a used one is a crap shoot unless you know the person
__________________
myspace.com/diesel_brad
96 F350 460 5pd 4x4 crewcab
94 F150 Lightning
86 F250 6.9 4spd 4x4
80 F350 429 C6 4x4
  #8 (permalink)
Old 06-26-2009, 08:54 AM
that guide is really helpful. i would be lying to you guys if i said i knew a lot about these transmissions, i really don't understand much about them. luckily i have a buddy with free space and plenty of tools, he pulls tranny's out of fed ex trucks and various other heavy duty vehicles so i'll at least have some worthy input when he's around.
HONESTLY, my original thought was that the PTO was not disengaging properly, causing it to rub up against additional components of the trans. Either that or it wasn't properly installed.
without having a similar gear to compare with, would it be possible to ID a worn gear to the untrained eye? i'm probably gonna get going taking it apart within the next 2 days.
  #9 (permalink)
Old 06-26-2009, 09:01 AM
ArdWrknTrk's Avatar
Quote:
I've learned this lesson the hard way before...
__________________
Jim
  #10 (permalink)
Old 06-26-2009, 11:21 AM
96 4D F150 96 4D F150 is offline
96 4D F150 is starting off with a positive reputation.
What are you doing with the truck?You may not need the overdrive the ZF has and could get away with an NP435 Granny low and PTO port.
For 200$ buy the 4WD ZF and resell it.Use that money to rebuild your ZF or buy another one.
I bought my ZF for 300$ and thought it was a smoking deal.I bought if off of Pirate4x4 from a local member so I felt alittle safer than a junkyard unit.Although I am buying a junkyard unit to put in a Jeep I have.
  #11 (permalink)
Old 06-26-2009, 11:39 AM
well it's a dump truck, so i have been dumping mulch, concrete, stone.... that sort of thing.
it is a work truck, so i am scrambling to find a replacement or get it opened up and see what the problem is.
insuring a vehicle that isn't making me money is a pain the ass =(
  #12 (permalink)
Old 06-26-2009, 04:07 PM
Doesnt sound like overdrive is a must.Check out an NP435.Probably stronger than a ZF but no Overdrive
  #13 (permalink)
Old 06-26-2009, 04:20 PM
ArdWrknTrk's Avatar
Stronger than the 542, but not the 547, which was used from '95
The T-19 has synchro 1st. IMO that's a + over the 435.
__________________
Jim
  #14 (permalink)
Old 06-26-2009, 04:29 PM
1980 Ford F-350
My Garage
Yeah, but w a small block in a mason dump, i think i would want a creeper 1st of the 435 or T18
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #15 (permalink)
Old 06-26-2009, 04:55 PM
well apparently the 542 was a light duty trans for a heavy duty truck.
i suppose o/d isn't necessary...
the np435 hard to find? it's for older models i presume?
Tags
ford , transmission , zf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
