Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 06-26-2009, 06:06 PM
ArdWrknTrk's Avatar
ArdWrknTrk ArdWrknTrk is offline
<--Dog is my Co-pilot
ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold ArdWrknTrk is a splendid one to behold
Quote:
Originally Posted by Diesel_Brad View Post
Yeah, but w a small block in a mason dump, i think i would want a creeper 1st of the 435 or T18
No creeper 1st in the T-19?
I can't get into double digits.
Mine is 6.32:1 (edit)but that might have been done when I swapped gearcases @ the transmission shop
__________________
Jim
'87 F-250 4V 460, T19, 4x4, 4.10 sterling 10.25" - Lil' Red
http://i246.photobucket.com/albums/gg117/donjamer/FTE%20Pics/blumax500-1-1.jpgFTE Fraternity of Blue Max
  #17 (permalink)
Old 06-26-2009, 07:25 PM
rikard rikard is offline
rikard is starting off with a positive reputation.
IIRC the 88 351 is a Windsor so it has the SBF bolt pattern, the Cleveland bolt pattern is different. If your doing a rebuild get a used transmission and rebuild it. I have bought two manuals from the "yard" and only had to replace the seals and front bearing. This will give you less downtime for the truck. From the sound(s) of it your tranny is probably full of chips so its trashing most of the rotating parts.. I wouldn't drive it much, it might jam and leave you stranded.
regards
rikard
__________________
Present-1995 Black F150 SC XLT 300 5 Spd
Past-1994 Red F150 SB XL 300 5 Spd
1983 Red F150 SB XL 302 AOD
1962 USPS 2.5 ton stepvan converted camper
223 3 speed DRW
1956 Red F100 Ma Bell uility bed 223 3 Spd
  #18 (permalink)
Old 06-27-2009, 12:10 AM
Rolando14 Rolando14 is offline
Rolando14 is starting off with a positive reputation.
yeah i am not driving it at all.
only to my buddy's shop
it really makes me nervous to operate it.
at all.
  #19 (permalink)
Old 06-27-2009, 01:09 AM
boggerted boggerted is offline
1989 Ford F-350
boggerted is starting off with a positive reputation.
Before you kill yourself over something minor, did you check the fluid? Is there enough? Does it have a odd smell or color? If its milky, it could mean it had water in it which would definitely cause noises.
__________________
2000 Ford Excursion-6.8L V10 gas guzzler
1989 Ford F350 4x4 351 5 speed-The Beast
1984 Ford F250- my project- 351w 4 speed w/granny, gauge set, glasspacks, Holley 4bbl, Edelbrock performer intake
  #20 (permalink)
Old 06-27-2009, 10:37 AM
i have not checked the fluid out yet, in all honesty
i will do that today, but i sincerely doubt that's the cause of all this noise/rough driving goin' on, but hey i guess i wouldn't really know.
  #21 (permalink)
Old 06-27-2009, 11:31 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l is starting off with a positive reputation.
Ummm, sorry for helpful info, but where can I get a 5 speed tranny for a 4.9l and all the clutch assemblies, etc as mine is a auto......
Does ZF make a tranny to fit a 4.9l?
thanks all-
-Wes
  #22 (permalink)
Old 06-29-2009, 07:11 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE.
The 351W and 351C both had small block bell housing bolt patterns.
Quote:
well apparently the 542 was a light duty trans for a heavy duty truck.
All the ZFs were heavy duty transmissions. There is another 5-speed, made by Mazda that is a light duty transmission, but they were never used in anything heavier than a light duty F250 and did not have a granny first gear. I wouldn't waste time trying to convert to a 4-speed, whether you need overdrive or not. Transmission swaps like that are often far more involved than taking out the first and installing the second.
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
  #23 (permalink)
Old 06-29-2009, 07:21 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is starting off with a positive reputation.
dont quote me but i believe the zf trans has to be pressed apart and back together. just something to think about
__________________
myspace.com/diesel_brad
96 F350 460 5pd 4x4 crewcab
94 F150 Lightning
86 F250 6.9 4spd 4x4
80 F350 429 C6 4x4
  #24 (permalink)
Old 06-30-2009, 08:54 AM
i'm unsure of what you mean by that dieselbrad?
  #25 (permalink)
Old 06-30-2009, 10:56 AM
nstueve's Avatar
nstueve nstueve is offline
nstueve is starting off with a positive reputation.
Quote:
dieselbrad is right... I have a 4.9L with the ZF 5-42 tranny and just bought a replacement since my origional case was cracked and the gears seized up... I got my ZF 5-42 replacement very cheap $90! Yes there is special tools that you need to take apart and repress the gears in the tranny. I don't know exactly what the pressing is all about since my buddy did mine for a case of beer and parts $$$. Look on Ebay.com find a ZF and buy it! You didn't pay that much for the truck so just buy a good tranny if you need the truck back on the road! If the one you have can be rebuilt, you can rebuild it and keep it or sell it to make some $$$ back. Here there is one from a F-150 which probably gave the unit light use compaired to what you are doing. ZF's are great trannys just stick with the OE!
http://cgi.ebay.com/ebaymotors/87-92...Q5fAccessories
And yes to the guy who asked 5-6 posts ago. The ZF 5-42 will fit behind your 4.9 I6. Just make sure to not buy a big block ZF because they have a different bolt pattern (that means ZF's that have been behind the 7.3 diesel and the 7.5 460 gas won't work~!) if you need more information just leave another post.
  #26 (permalink)
Old 06-30-2009, 11:25 AM
1980 Ford F-350
My Garage
All the bearings are pressed onto the shafts and then pressed into the case. Not like the T18-T18 -435 which all just fall apart and fall back together
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #27 (permalink)
Old 06-30-2009, 05:05 PM
thanks nstueve, that's a really clean looking zf.... but again, it's a lot compared to what i've spent on the truck itself
what is this tool called does anyone know?
  #28 (permalink)
Old 07-02-2009, 09:09 AM
nstueve's Avatar
I'm pretty sure that it's a set of tools and they are expensive! I kind of remember looking into getting them myself until I found out how much they were going to be! I think the kit was like $300 or more but can't completely remember... Maybe someone else could help??? Might want to try calling the Ford Dealership and asking their transmission mechanic...
  #29 (permalink)
Old 07-02-2009, 10:20 AM
1980 Ford F-350
My Garage
THAT IS A DEAL!!!! theses are 600+ You are a fool to pass it up if they offer a warranty. The part alone can cost twice that to rebuild yours if there is some bad hard parts
__________________
94 F150 Lightning
80 F350 429 C6 4x4
  #30 (permalink)
Old 07-02-2009, 07:09 PM
EPNCSU2006's Avatar
I know frederic has rebuilt at least one ZF, maybe send him a PM if he doesn't chime in here.
__________________
Eric
Tags
ford , transmission , zf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
