Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-25-2009, 04:49 PM
Sunwest Sunwest is offline
Sunwest is starting off with a positive reputation.
Transfer case recommendation for 78 Bronco
Hi all, I've got a 78 Bronco with a fresh 400 and rebuilt C6. The thing currently has the NP203 transfer case, & I was thinking about slapping in a NP205 that I have laying around. Are these my only two options?
  #2 (permalink)
Old 06-25-2009, 05:12 PM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
1981 Ford Bronco
AbandonedBronco is starting off with a positive reputation.
I believe an NP208 will work as well. It's what came on the 80+ (besides the BWs).
Plusses. 2.61 low range vs. the 1.96? low range of the NP205. Quite a bit lower range.
Minuses. Its chain driven instead of gear driven, and it's aluminum.
__________________
4bbl Holley 390 w/ Offenhauser DP intake. 4 speed Manual w/OD. K&N air filter, EFI manifolds, 2.5" exhaust.
3.00 rear end and 2000 RPMs @ 80mph!
Boise, Idaho
  #3 (permalink)
Old 06-25-2009, 05:15 PM
kenpobuck kenpobuck is offline
kenpobuck is starting off with a positive reputation.
I believe that all the tcases behind the automatics were 31 spline. I have used np208 and bw1356 in my Bronco with a c6. The np203 has a lower range than the 205 but the 205 is all gears no chain. The rest of them are all chain driven.
__________________
DON'T BUY IT ..FAB IT!!!!
88 Bronco XLT 6.9 IDI, C6, Dana60 rear, 50 front, 3.55 gears, 33x12.5x16.5's. built by me becuase I just had to!
Kentucky Chapter Member
  #4 (permalink)
Old 06-25-2009, 06:02 PM
I am leaning towards the NP205 because of it being gear driven. Is there a way, when rebuilding the NP205, to re-gear it to have the lower "low" gear?
  #5 (permalink)
Old 06-25-2009, 06:36 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a good reputation on FTE. Kemicalburns has a good reputation on FTE.
since you have both cases i would go with a doubler build 203/205
__________________
94 XLT 5.8/E4OD
6"ProComp Stage II 35x12.5x15 BFG MT's ,
4.88 gears f/r
JBA shorty, Custom Y pipe,3" exhaust
Warn HS9500I
installing soon: Edelbrock efi truck intake, aussie locker front/rear
http://www.supermotors.org/registry/...il.php?id=4158
  #6 (permalink)
Old 06-26-2009, 12:45 AM
Quote:
Isn't a double system mainly used for rock crawling and so forth? I am planing on ussing this rig mainly for a camping rig and fun around old logging roads.
  #7 (permalink)
Old 06-26-2009, 09:47 AM
1981 Ford Bronco
If that's the kind of off-roading you're going to be doing, maybe just throw the 208 in there and get yourself the extra low range. They used them for a long time in the 80+ Broncos and they're not exactly known as a weak point. Some see some pretty serious abuse with mudding and rock crawling.
__________________
Boise, Idaho
  #8 (permalink)
Old 06-26-2009, 10:01 AM
i would run a doubler for sure even for those uses. the thing is you have a C6 auto so gearing is huge. you could run a 4.10's with 35" tires so your hwy rpms are decent and then when your out playing you will always have extra low gear options.
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
Warn HS9500I
  #9 (permalink)
Old 06-26-2009, 04:38 PM
Could someone explain to me exactly what a doubler is and how in general it is setup so I can understand it better? A pic would be great
  #10 (permalink)
Old 06-26-2009, 04:41 PM
1981 Ford Bronco
I was curious about this too.
__________________
Boise, Idaho
  #11 (permalink)
Old 06-26-2009, 05:08 PM
alxsnmr alxsnmr is offline
1991 Ford Bronco
alxsnmr is gaining momentum as a positive member of FTE.
Basically, the NP203/205 doubler uses the range gear of the NP203 transfer case as an intermediate between the 205 and the transmission (think of it as a gear splitter if you will). There is a custom adapter needed to mount the NP205 and clock it in the right position so that the 205 does the 4x4 selection.
http://www.alaska4x4network.com/showthread.php?t=8768
the above thread highlights this and has many pictures that show the 203 range gear on the front of a 205 transfer case. See the final pictures of what the finished doubler looks like.
__________________
Stock 1978 F250 Custom regular cab 4x4 with 351M and 4 spd.
1991 Bronco silver anniversary, 5.8L EFI, E4OD swapped for C-6, custom trimmed rear fenders finished in rust.
2009 Fusion SE 2.3L 5spd Red/black cloth n leather
  #12 (permalink)
Old 06-26-2009, 05:25 PM
also check out the many threads on Pirate4x4 regarding a doubler.
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
Warn HS9500I
  #13 (permalink)
Old 06-27-2009, 11:45 PM
All right, now that I know all about the doubler, I must have one! I live in Oregon, does anyone have a clue as to were I could get the custom parts at? I have the NP203 and NP205 already.
  #14 (permalink)
Old 06-29-2009, 11:01 AM
Where in oregon would help lol. Im in central oregon myself, how about u
__________________
94 XLT 5.8/E4OD
4.88 gears f/r
Warn HS9500I
  #15 (permalink)
Old 06-29-2009, 04:25 PM
I live right out of portland, but am over in Redmond every other month or so.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
