can you switch a E4od to a c6?
I have a 1995 F350 4x4 with a E4od transmission that has overheated and slips when you take off in drive. The rest of the gears seem to work including od. It seems to me I can get a rebuilt c6 cheaper than rebuilding the E4od. I may be wrong on the cost of rebuilding the E4. If someone has a suggestion on what may be wrong with the E4 I would appreciate the input. Thanks
The TPS has nothing to do with the tranny.
You will need the above listed parts but there are somethings you can get to soften the blow to installing the C-6. You can 'Fool' the computer by retaining the MLPS connected to the wiring loom but left in the neutral position or swap the computer appropriately and integrate the C-6 neutral safety switch into the wiring loom, Find the driveshafts out of a similar truck to yours but with either the C-6 or one of the older 4spds, You may be able to reuse the cross-member but i used one from a truck that had a C-6/AOD in it, use the shift linkage after the column linkage that was installed on the C-6 because it will be the right length and it will have to provision for kick down cable, you will need the kick down cable, if you have a manual shift transfer case you will need the appropriate length hardware as well. The transmission cooling lines will fit into the C-6 but you will need to fit them to the C-6 length-wise by either bending with out kinking or physically shorten them to the C-6. The C-6 will be a bolt in deal afterwards.
(even though you can get a rebuilt C-6 cheaper than the E4OD, the cost of swapping over nearly equals out to just rebuilding the E4OD)
Other than installing a tranny temperature gauge and monitoring it when it begins to over heat. You already have a secondary cooler (didnt say if it was big enough to cool though) , but installing an external oil filter that you can easily change can reduce harmful particals in the tranny.
4x4slik
02-18-2016 08:55 AM
hauswulf
10-16-2015 10:02 AM
antiquetvguy
05-13-2015 09:14 PM
dinikin
02-10-2007 11:30 AM
