Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #16 (permalink)
Old 07-09-2009, 02:45 PM
rlh68050's Avatar
rlh68050 rlh68050 is offline
rlh68050 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by EXv10 View Post
Sorry but I can't agree. There is nothing good about old oil. It is contaminated and contains a small percentage of it's original oiling capabilities. It will shurly lead to the demise of the tranny. The rest of the trans needs good oil also (mainly the bushings). There are a lot of tales about auto trans because they are expensive to fix and people dream up remedies for it. The band and clutch material is hard enough so there's nothing to "wash away". You can take a driven clutch disc out of a clutch pack on an old tranny and clean it up in solvent and it will look exactly the same. It's not like it is leather or something that absorbs contaminants to the point where it gets denser.
Ok, if I have a trans that is slipping and change the fluid nothing will change - for better or worse?
__________________
Rob
2001 Excursion
4x4 V10
  #17 (permalink)
Old 07-09-2009, 03:23 PM
EXv10's Avatar
EXv10 EXv10 is offline
EXv10 is gaining momentum as a positive member of FTE. EXv10 is gaining momentum as a positive member of FTE.
They usually slip due to lack of pressure from the front pump and not clutch wear. If it is slipping it will not last long anyway. It depends on the tranny and exactly what is wrong with it so I won't venture to answer that question but I whould at least change the pan oil if it was mine. Old oil should give more friction at the plates but less pressure from the pump.When I was a mechanic (long time ago) they used to just fix whatever was worn and charged much less but I know know if they still do that. It's like a disease; the earlier you fix it the less it will cost you. Sometimes it is just a pump and seal and maybe a few friction clutches. (And o-ring seal kit)
  #18 (permalink)
Old 07-09-2009, 04:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Former Ford AutoTrans Eng
Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold
In my opinion there is NEVER a detriment to changing the trans fluid. If the trans isn't damaged it will help it. If it is damaged it won't fix it, but it won't kill it, either. It may already be dead when the new fluid is installed, and finish dying afterwards, but I do not believe that new fluid will harm ANY transmission.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #19 (permalink)
Old 07-09-2009, 10:47 PM
EXv10's Avatar
Quote:
I'm with you 100%
  #20 (permalink)
Old 07-10-2009, 12:49 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
Never fry bacon NAKED!
2002 Ford F-250
My Garage
Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold
Quote:
Originally Posted by rlh68050 View Post
As the transmission ages, the friction material on the clutch disc packs and bands wears and becomes suspended in the fluid. This seeming is all ok, until you drain the old fluid and put new in. New ATF very high cleansing properties (every get new ATF on your hands, it's pretty clean stuff) and proceeds to "wash away" much more of the remaining friction material from the clutches than the old fluid would, hence the trans fails.....as long as you have regularly changed your trans fluid (every 20-30k or so) that you can continue doing it and the trans life will benefit.
That's failed logic.
If new tranny fluid "washes away" the friction material, then changing the tranny fluid "every 20 - 30k" will cause the friction material to wash away FASTER, causing the tranny to fail quicker.
Stewart
__________________
The Brotherhood of FTE <~click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
2002 PSD F250 SC 4x2: 38R, AC codes, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody
2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
  #21 (permalink)
Old 07-10-2009, 12:54 AM
1medic 1medic is offline
1medic is starting off with a positive reputation.
Don't forget. The same mechanic that tells you not to change you tranny fluid "until it acts up". Is usually the same mechanic you go to when your tranny "is acting up" and they tell you "you need a new transmission". Hmmmm???? Makes you wonder where their coming from. Lets say you have 150,000 miles and you never changed the fluid and you have to replace / rebuild the tranny. Lets say a 30K service is $200. You would have spent $1000 for maint. For a rebuild you'll spend $3000 - $4000. Hmmmmmm???? Now which service would your mechanic rather do? Any mechanic that tells you not to change the fluid at regular intervals is an idiot!
  #22 (permalink)
Old 07-10-2009, 10:31 AM
EXv10's Avatar
I think 99% of the old tales (like don't change your oil) comes from people that have never had a transmission apart (and probably don't own a wrench) and they come up with this stuff because they are grasping for a remedy thay will prolong their expensive repairs and unfortunately other people that are in the same boat believe them..........no offense RLH (op)
  #23 (permalink)
Old 07-17-2009, 04:25 PM
Konarain Konarain is offline
Konarain is starting off with a positive reputation.
Such a great debate! Thanks for the info, guys!
Aloha
Tags
05 , 2004 , 30k , automatic , change , changing , cost , excursion , f150 , f250 , fluid , ford , oil , put , roadstar , transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
