Quote:
Originally Posted by FL-Mudd-Duck
they didn't use the aod behind a diesel eng it will eather be a c-6 or a e4od in it both are very good trannys the back of the c-6 pan is S shaped and has a kick down rod hooked with the shift linkage and has a vacume module on the right rear corner
awsome thanks, if things go right in the next 2 hours i will have a 89 F250 4x4 Diesel extra cab XLT
