Go Back   Ford Truck Enthusiasts Forums > Bronco > Big Bronco (1978 - 1996)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Big Bronco (1978 - 1996) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-25-2009, 11:00 AM
aurgathor aurgathor is offline
aurgathor is gaining momentum as a positive member of FTE.
rear window sticking/slow
I have a problem with my rear window on my '95 Bronco: when I try to lower it, it moves a couple of inches, then it slows down and eventually gets stuck, but if I grab it and help by pulling it down, it will come down all the way just fine. It is kinda slow going back up, but it can do that without any help from me
Does anyone what is the most likely cause of this? Tired motor? Lack of lubrication? Misaligned or bent parts? Something else?
TIA
  #2 (permalink)
Old 06-25-2009, 11:41 AM
Zrock Zrock is offline
Zrock is starting off with a positive reputation.
Had the same problem.. had to scrape all teh old lube off the gears and apply new works like a charm now
  #3 (permalink)
Old 06-29-2009, 01:44 PM
DerekVS DerekVS is offline
DerekVS is starting off with a positive reputation.
TIA
On my '94, it turned out that there was so much caked dirt and dust in the fuzzy window slides that it was scraping and stopping the window. I noticed that if I pushed on the window to help it up, it was fine. So...
I cleaned it all out and added some silicone lube in the slides and now it goes up faster than it ever has.
  #4 (permalink)
Old 06-29-2009, 08:19 PM
g_k50's Avatar
g_k50 g_k50 is offline
1990 Ford Bronco
My Garage
g_k50 is starting off with a positive reputation.
I like the silicone lube on the weatherstriping. It helps and there is some controversy about it softening the paint so be careful putting it on.
  #5 (permalink)
Old 06-29-2009, 08:44 PM
Wagion's Avatar
Wagion Wagion is offline
2008 Ford F-350
Wagion is starting off with a positive reputation.
Time to clean.
Take the access panel off.
Flip down locks and put window up. ***Make sure you support it on something***
Use a shop vac and suck anything laying in bottom of tail gate out.
Check the two guide rails see if they are bent or rusted or anything
Spray down the gears with degreaser.
wipe off everything.
Apply new grease to gears
apply grease or silicone to or at least Armoural to all weather stripping and rubbery parts.
__________________
2008, F350, XLT, 4x4, SRW, 6.8L V10, 6 Speed Standard, Regular Cab
  #6 (permalink)
Old 06-30-2009, 02:10 AM
Thanks for the replies. I was looking it over the weekend, and it appears to me that I would need to take out at least the glass, but maybe more to properly clean and relubricate everything
Since the weather is good and I'm doing some construction hauling bunch of stuff, I may just keep the window down for a while....
  #7 (permalink)
Old 06-30-2009, 03:37 AM
Wagion's Avatar
2008 Ford F-350
You have to drill out four rivets to remove the glass. You can put the tailgate down and then flip the latch on each side closed and raise the window you just need to make sure you put some saw horses or something the right hight under it to support it then you can do all the work. The replacement rivet can be hard to find if you do decide to take them out you can use nuts and bolts with nyl lockers but be very careful not to over tighten
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
