Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-25-2009, 10:33 AM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1999 Ford F-250
superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold
Riffraff HPX on an early 99
For all you early birders out there that are considering this product, I wanted to let everyone know that I installed one recently (finally... sorry it took me so long Clay!) and it fits perfectly! It comes very, very close to the turbo, only about 1/32" clearance, but it drops right into place with no clearancing or re-bending of the HPX needed. Install would have taken all of 10 minutes if I hadn't taken so many photos (to be posted later). As far as any changes I noticed- a smoother idle (BIG change) and a decrease in a hard to describe sound my truck makes at idle, most likely due to leaky injector O-rings. It also sounds different at speed at times- almost like I can hear the injectors better. Great product for the price- thanks Clay!
__________________
Chase
1999 F250 PSD CC SB 4x4 - his
2000 Explorer XLT 4x4 - hers
PAA Member #2
God speed Markadeck, you will be missed
ThumperTalk / All Things Moto! / SnoWest / SAWS / BRC
  #2 (permalink)
Old 06-25-2009, 10:42 AM
F250_'s Avatar
F250_ F250_ is offline
Still learning every day!
2002 Ford F-250
F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of F250_ has much to be proud of
Chase... did you go with the hose or the hard tube?
__________________
http://guzzle.rbmicro.com/7pt3/Mods.html
Become a SUPPORTER!!
  #3 (permalink)
Old 06-25-2009, 11:17 AM
1999 Ford F-250
Its the hard tube version Pete.
__________________
Chase
PAA Member #2
  #4 (permalink)
Old 06-25-2009, 01:19 PM
PwerStroke99's Avatar
PwerStroke99 PwerStroke99 is offline
PwerStroke99 is gaining momentum as a positive member of FTE.
wheres the pictures????
__________________
Ken
99.5 7.3L PSD, GTP38R BB, Dp-tuner F6, TYMAR Intake/Coolant filter, 6.0L IC, MBRP 4" Turbo Back exhaust w/6" tip, BTS, Casserly 250cc Hybrids. Future mods-- Big Oil, ITP RR W/fuel bowl del, Airdog
  #5 (permalink)
Old 06-25-2009, 01:22 PM
RussB's Avatar
RussB RussB is offline
RussB is gaining momentum as a positive member of FTE.
This Post is useless without pictures
Sorry buddy...... I got my balls busted last time.. I got to get you guys back when I get the chance !!!
__________________
Russ PAA# 25
03, 350 Lariet, 315 Toyo M/T's, 9000lb Warn winch frnt/rear recv mount, 4 ProComp halo's (frt bump), Warn man hubs, 6637 / Pete's cover, CCV, Gauges, 4" ProComp Lift, 4" SS Magnaflow , GPR LED, SS HPX, DP Tuner NS,STK,HIGH IDLE,40T,DECEL,80T,80ECO,120/ gauge switch, Overboost, Avic D3, F650 dash, Aeroforce scan gauge !
  #6 (permalink)
Old 06-25-2009, 01:23 PM
1999 Ford F-250
Quote:
At home on the camera!
__________________
Chase
PAA Member #2
  #7 (permalink)
Old 06-25-2009, 01:27 PM
Quote:
WTF!!!! Slacker~ Is it anything like the KCM HPX ITP sells? thats the one i have on mine, i like it and noticed the same things u did after install.
__________________
Ken
  #8 (permalink)
Old 06-25-2009, 01:29 PM
1999 Ford F-250
Similar, but it doesn't dip down into the valley like the KCM. It just has an outward bend in it to clear the turbo.
__________________
Chase
PAA Member #2
  #9 (permalink)
Old 06-25-2009, 01:45 PM
cjfarm11 cjfarm11 is offline
cjfarm11 is starting off with a positive reputation.
Whats the HPX?
__________________
Curtsey!
Early 99 F-350 Lariat 4DR, LB, DP Tuner, 17* HPOP, 4" Magnaflow exhaust, 6637 Mod, Late Model Turbo with 1.0 Exhaust housing, Bellowed Up-pipes, HPX, CCV Mod, OBA, Shift Kit and Billet Convertor, 6.0 Tranny Cooler.
  #10 (permalink)
Old 06-25-2009, 01:50 PM
1999 Ford F-250
Quote:
Originally Posted by cjfarm11 View Post
Whats the HPX?
HPX = high pressure crossover. It ties the 2 high pressure oil rails in the heads together.
__________________
Chase
PAA Member #2
  #11 (permalink)
Old 06-25-2009, 02:03 PM
03_PSD's Avatar
03_PSD 03_PSD is offline
Black Smoke
2003 Ford F-250
03_PSD has a very good reputation on FTE. 03_PSD has a very good reputation on FTE. 03_PSD has a very good reputation on FTE.
Whats the HPX?
Smooths out the idle alot, our engines should have come stock with these IMHO.
__________________
Glenn
03 F250 Lariat 4x4~6 Gears~ProComp Lift~Front Ranch Hand w/4 Hella's and Rear Ranch Hand~Tony Wildman Tuned~08 Console~4 Gauge Pillar~Van Turbo/1.15/WW~4" Exh~6637 w/ Pete's Cover~ITP OBA~Clay's AIH Delete~SS HPX~CCV~CCK~Fuel PSI Gauge~Foil Delete~Alum. Rear Diff~203˚ w/Billet Housing~Recon Smoke Cab Lights~IH Emblems~Fumoto Plug~IH UP-PIPES
  #12 (permalink)
Old 06-25-2009, 02:05 PM
Really! Sounds like a simple thing to install as well! What is the price?
__________________
Curtsey!
  #13 (permalink)
Old 06-25-2009, 02:10 PM
03_PSD's Avatar
Black Smoke
2003 Ford F-250
PM Clay with Riffraft Perfomance (He's one of our great sponsors!!) and he'll take care of you.
__________________
Glenn
  #14 (permalink)
Old 06-25-2009, 02:20 PM
1999 Ford F-250
What Glenn said. It's very affordable, I can't recall the exact price.
__________________
Chase
PAA Member #2
  #15 (permalink)
Old 06-25-2009, 02:36 PM
hucka1a's Avatar
hucka1a hucka1a is online now
Welcome Home 776th!!!
hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE. hucka1a has a great reputation on FTE.
Thanks Chase. To my knowledge the Riffraff HPX is the ONLY HPX available that you don't have any clearance issues on the early 99. I hope to be ordering mine soon.
__________________
Huck PAA Member 66, E.T.A.P.S. Member
early 99 (11/24/98) F250, PSD, auto, 4x4, ec, short bed.6637/wrapped by Pete, CCV Mod, 6.0 Trans Cooler, MKO 4", '05 Power Seats(Thanks Scott), PMT2, Transgo Tugger, DP Tuner F6, diy oba, Isspro Performax, pyro, boost,Trans temp, and EOT mueckster 710 cap,True-Trac(Thanks Cory),diy Coolant filter.Riffraff Diesel Pete's Covers DP-Tuner Roadside Help Network
Tags
hpx , kcm , ss
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
