Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 07-04-2009, 03:54 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
Platinum Sponsor
Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE.
Quote:
Originally Posted by agg_bagg View Post
clay is there a better one, like vs the hard or soft, because the price between the two is alot different. is it just the way you have to build the soft one that makes the price difference.
Exactly, the price is much higher because of the materials. We offer both because of user preferance. Personally I run the soft, but there is nothing better about it that doesn't fall into the theory category.
__________________
Clay 541.879.1052 www.RiffraffDiesel.com
Diesel O-Rings by Guzzle
Riffraff Facebook Page
Parts Guy Ed - The one and only choice for OEM Parts
  #32 (permalink)
Old 07-14-2009, 08:47 PM
PaulwestSki PaulwestSki is offline
PaulwestSki is starting off with a positive reputation.
Will the same line work on both the 7.3 and the 6.0 ?????????
  #33 (permalink)
Old 07-14-2009, 09:58 PM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1999 Ford F-250
superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold
I don't believe so PaulwestSki.
__________________
Chase
1999 F250 PSD CC SB 4x4 - his
2000 Explorer XLT 4x4 - hers
PAA Member #2
God speed Markadeck, you will be missed
ThumperTalk / All Things Moto! / SnoWest / SAWS / BRC
  #34 (permalink)
Old 07-14-2009, 10:02 PM
1999 Ford F-250
Quote:
Originally Posted by CampSpringsJohn View Post
I finally got around to installing one on my 02 yesterday. I bought 2, one for my 97 also. I got the soft lines myself. Unfortunately, on my 97, there isn't a place where the plugs are accessible straight across from each other. Is there a different version for the older trucks, or do you have to re-route the HPO lines?
BTW, it does appear to idle smoother, and quieter.
On the OBS you need to move one of the HPOP lines to a different port so you can install the HPX. Sorry I didn't see this sooner!
__________________
Chase
PAA Member #2
  #35 (permalink)
Old 07-20-2009, 07:50 PM
Does someone make a line for the 6.0 or is this not an issue on the 6.0??
  #36 (permalink)
Old 07-20-2009, 10:43 PM
nhill2090 nhill2090 is offline
nhill2090 is gaining momentum as a positive member of FTE. nhill2090 is gaining momentum as a positive member of FTE.
I see someone posted something about ITP's HPX not fitting early 99's, but I have had it installed on mine for a couple years now. Fit like a glove
__________________
Nic
1999 (early) F250 XLT SC LB 4x4
6" lift, 5" exhaust and a BTS trans. That sums most of it up.
PAA Member #1
  #37 (permalink)
Old 07-21-2009, 02:22 PM
cjfarm11 cjfarm11 is offline
cjfarm11 is starting off with a positive reputation.
I installed the soft hose from clay at riff raff and it is a great product. Well made to with good materials. I will never have to worry about any problems with that things. And as for the noise, it does idle a lot smoother and noise is slightly less as well.
__________________
Curtsey!
Early 99 F-350 Lariat 4DR, LB, DP Tuner, 17* HPOP, 4" Magnaflow exhaust, 6637 Mod, Late Model Turbo with 1.0 Exhaust housing, Bellowed Up-pipes, HPX, CCV Mod, OBA, Shift Kit and Billet Convertor, 6.0 Tranny Cooler.
Tags
hpx , kcm , ss
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
