Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 06-27-2009, 12:34 AM
Bird Dog's Avatar
Bird Dog Bird Dog is offline
Bird Dog is starting off with a positive reputation.
So what's the difference between the KCM S.S.HPX and Clay's HPX?
Anybody got any pic's??
I'm ordoring one on Monday. So, which one should it be?
__________________
Rhett
Early 99 F350 Lariat 4x4 CCLB 7.3 PSD,DP Tuner F5 switch,ITP Overboost Annihilator,Power Braker, Triple Gauges,kwikfilter,4"Turbo Back Exhaust, Muffler Delete,Transgo Shift Kit,Air Lift,CCV Mod, Prodigy Trailer Brake,Skyjacker 7000's,2 Interstate Megatron-Plus Batteries,19.5" Visions with 265/70's load range G Yokohama TY 303.
If it don't blow black take it back!!
  #17 (permalink)
Old 06-29-2009, 10:26 AM
superduty4x4's Avatar
superduty4x4 superduty4x4 is offline
1999 Ford F-250
superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold superduty4x4 is a splendid one to behold
I'll try to get my wife to send the pics , hard to see installed though.
Clay's HPX doesn't dip down into the valley, it's a straight run across from head to head. Clay's HPX also isn't SS, he said he couldn't find a good reason that SS was any better than "regular 'ol" steel.
__________________
Chase
1999 F250 PSD CC SB 4x4 - his
2000 Explorer XLT 4x4 - hers
PAA Member #2
God speed Markadeck, you will be missed
ThumperTalk / All Things Moto! / SnoWest / SAWS / BRC
  #18 (permalink)
Old 06-29-2009, 12:02 PM
1999 Ford F-250
Here are the photos. You can do the install without removing anything, but I found it much easier to do with the intake removed. Photos don't show much but you get the idea.
That last photo is kind of crappy but oh well This would have been a 10 minute job if not for the photos.
__________________
Chase
PAA Member #2
  #19 (permalink)
Old 06-29-2009, 12:12 PM
03_PSD's Avatar
03_PSD 03_PSD is offline
Black Smoke
2003 Ford F-250
03_PSD has a very good reputation on FTE. 03_PSD has a very good reputation on FTE. 03_PSD has a very good reputation on FTE.
Looks like a great product, as everything Clay sells!!
__________________
Glenn
03 F250 Lariat 4x4~6 Gears~ProComp Lift~Front Ranch Hand w/4 Hella's and Rear Ranch Hand~Tony Wildman Tuned~08 Console~4 Gauge Pillar~Van Turbo/1.15/WW~4" Exh~6637 w/ Pete's Cover~ITP OBA~Clay's AIH Delete~SS HPX~CCV~CCK~Fuel PSI Gauge~Foil Delete~Alum. Rear Diff~203˚ w/Billet Housing~Recon Smoke Cab Lights~IH Emblems~Fumoto Plug~IH UP-PIPES
  #20 (permalink)
Old 06-29-2009, 12:26 PM
Riffraff Performance's Avatar
Riffraff Performance Riffraff Performance is online now
Platinum Sponsor
Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE. Riffraff Performance has a great reputation on FTE.
__________________
Clay
Riffraff Diesel: Contact Us
Diesel O-Rings by Guzzle
Riffraff Facebook Page
Parts Guy Ed - The one and only choice for OEM Parts
  #21 (permalink)
Old 06-29-2009, 12:59 PM
1999 Ford F-250
That's the one. I got too carried away with getting it in and forgot to take a pic before I installed it
__________________
Chase
PAA Member #2
  #22 (permalink)
Old 06-29-2009, 01:59 PM
Platinum Sponsor
Quote:
I suffer from the same thing. I always think I am going to take pics and I get to excited and into the mods and forget all about it.
__________________
Clay
  #23 (permalink)
Old 07-04-2009, 03:03 AM
agg_bagg agg_bagg is offline
agg_bagg is gaining momentum as a positive member of FTE.
so clay what is the difference between the hard and the soft lines
__________________
Jeron
Early 99 F250 SD PSD Super Cab, 210,000 miles, 4" lift 35" tires, Hutch & Harpoon, CCV, 6637, TransGo Tugger with rebuild, DiPricol Gauges EGT/Boost/Trans Temp, Door Lock Foil Fix
  #24 (permalink)
Old 07-04-2009, 03:09 AM
Platinum Sponsor
Quote:
Mainly it boils down to user preference. Soft lines used to be more predominant but there were a few failures of the hose over time from heat and pressure. I am not aware if this was because of inferior materials or workmanship. That is the reason our soft line is made from the best materials and then to put it over the top we used a firesleeve for even more heat protection. So either way it gets the job done. Let me know if I can help you further, and don't hesitate to give us a call. Thanks
__________________
Clay
  #25 (permalink)
Old 07-04-2009, 06:53 AM
Supercab Supercab is offline
Supercab is gaining momentum as a positive member of FTE. Supercab is gaining momentum as a positive member of FTE.
Wink
Guys, I think with Clay's top notch customer service that RiffRaff is going to go places!!!
__________________
Support FTE
  #26 (permalink)
Old 07-04-2009, 08:34 AM
CampSpringsJohn CampSpringsJohn is online now
CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold CampSpringsJohn is a splendid one to behold
I finally got around to installing one on my 02 yesterday. I bought 2, one for my 97 also. I got the soft lines myself. Unfortunately, on my 97, there isn't a place where the plugs are accessible straight across from each other. Is there a different version for the older trucks, or do you have to re-route the HPO lines?
BTW, it does appear to idle smoother, and quieter.
__________________
1997 Super Duty, PSD,6637, high idle, 50hp, & 80hp. 150cc injectors.
2002 F250 Crew Cab, 8' bed, 4X4, PSD, 6637, 4" magnaflow exhaust, high idle, 50, 75 tow, 100, 120, & 140, HPX Crossover
Kentucky Chapter Member
  #27 (permalink)
Old 07-04-2009, 09:40 AM
PwerStroke99's Avatar
PwerStroke99 PwerStroke99 is online now
PwerStroke99 is gaining momentum as a positive member of FTE.
Clay,
How much does that stainless line cost? I have the KCM line from ITP and really like it. Im curious is there is a different between the two in how they work with the KCM having deeper bends and going down into the valley as compared to hows yours is designed.
__________________
Ken
99.5 7.3L PSD, GTP38R BB, Dp-tuner F6, TYMAR Intake/Coolant filter, 6.0L IC, MBRP 4" Turbo Back exhaust w/6" tip, BTS, Casserly 250cc Hybrids. Future mods-- Big Oil, ITP RR W/fuel bowl del, Airdog
  #28 (permalink)
Old 07-04-2009, 10:16 AM
IDPisan's Avatar
IDPisan IDPisan is offline
IDPisan is gaining momentum as a positive member of FTE. IDPisan is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by hucka1a View Post
Thanks Chase. To my knowledge the Riffraff HPX is the ONLY HPX available that you don't have any clearance issues on the early 99. I hope to be ordering mine soon.
I got my KCM HPX from ITP and didn't have any issues with clearance.
__________________
My two cents, Jeff
Early 99 F350 4X4 CC DRW 6spd. 6637, MKO 4" turbo back 5" straight piped exhaust 6" tip, ISSPro Gauges, Pyro, Boost, Water temp, DP Tuner Stock, 40tow, 60tow,80econo, 120race, KCM S.S. HPX line, ITP Overboost Annihilator, Auto Enginuity, GPR LED Indicator. 6.0 intercooler, CCV mod, EBPV delete,Wastegate Mod. 320,000 miles and counting.
  #29 (permalink)
Old 07-04-2009, 01:44 PM
Platinum Sponsor
Quote:
Originally Posted by PwerStroke99 View Post
Clay,
I'm not able to post pricing on the open forum but you are welcome to PM or call, sorry about that. The difference in mine and the KCM is basically as you stated with the bends. We decided to take the shortest and most direct route to keep it easy on the install and on the wallet. They both perform the same function.
__________________
Clay
  #30 (permalink)
Old 07-04-2009, 02:38 PM
clay is there a better one, like vs the hard or soft, because the price between the two is alot different. is it just the way you have to build the soft one that makes the price difference.
__________________
Jeron
Tags
hpx , kcm , ss
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
