Quote:
Originally Posted by forcury
Trying to replace pass. side dual piston caliper. Every parts store lists both sides as the same. I have no idea how that can be , due to the total opposite set up on each side. Am I missing something ? Any idea where to obtain the correct version ? any info would be of help .
Have you physically looked at your calipers?
Are they not the same???.....If more than one source is showing the same caliper for both side, then it must be the way it is.
Before I go any farther though, I would simply look at the ones on the truck.
