Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-25-2009, 07:32 AM
DZL JIM's Avatar
DZL JIM DZL JIM is online now
FTE Sponsor
DZL JIM is gaining momentum as a positive member of FTE.
Another rear disk conversion thread...
So I am seriously contemplating doing a rear disk on a drag truck project I have that the drums just won't seem to hold the power.
I did some reading at another site that had a few guys insist on using Super Duty calipers because they were better then the older Chevy caliper, etc. No idea how they concluded this...
Anyway, from the Rock Auto website, I got the bore sizes from a 2001 F-250 front and rear caliper, and bore sizes for a 1980 Chevy front, with 2 different bore sizes listed. Not sure why there are 2 different ones. ??
Results in area of the Piston bearing on the Pad (area of the circle):
2001 Front dual Piston: 7.06 sq in of bearing.
2001 Rear dual Piston: 4.98 sq in.
1980 Chevy truck front #184124/5: 6.776 sq in.
1980 Chevy truck front #184122/3: 7.819 sq. in.
It seems that the old Chevy single piston has more surface area than the '01 rears, and about as much as the fronts.
Questions:
1) What are the benefits of dual Pistons over a single? Is it exclusively to spread the load over the length of the pad and this gives 'better' stopping/holding?
2) Has anyone tried the '80 #184122/3 with the larger Piston?
The Chevy parts are 1/2 the cost of the Ford parts and if they work just as good it's hard not to go that route...
Disclaimer: Parking/e-brake not needed for drag truck, so I'm not looking at e-brake applications this time.
Thanks.
__________________
'96 F-350 Reg Cab 4x4 PSD
'97 F-350 CC Short Bed 4x4 PSD
StackCovers.com
DieselJunk.com
DZLJIM.com
  #2 (permalink)
Old 06-25-2009, 07:51 AM
Talyn's Avatar
Talyn Talyn is online now
1994 Ford F-250
Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE. Talyn has a very good reputation on FTE.
Well, as for dual and single. You can really think about it simply.
Is an object easier to move with a large footprint, or a small footprint?
1 piston will apply pressure in only one spot on the pad, a dual piston will apply pressure in 2 spots on the pad, thus more surface area is applying pressure to the rotor.
Thus, even with a slightly smaller surface area, the Dual piston will have more stopping power. More pressure is distributed throughout the pad, then the larger single piston.
__________________
Talyn (AKA: William) - Resident Sheep Shearer
1994 - F250 - Direct Injection Turbo Diesel, 5 speed, 4x4, Standard Cab.
Rosewood Stage 1's, 6 pos PHP Tuner, 6637, Midwest Short Throw Shift Kit.
Head over to www.midnightmods.com to see some of my projects.
Midwest Shift Kit- http://www.midnightmods.com/2009/11/...ifter-kit.html
  #3 (permalink)
Old 06-26-2009, 11:19 AM
DZL JIM's Avatar
FTE Sponsor
I hear what you're saying. I've been thinking abotu this a lot over the last few days, never really thought about it before.
Why I measured this stuff, if the Chevy truck pad is wider to cover the larger Piston, it still has a certain surface area bearing on the rotor. If the pad for the dual Piston is narrower but longer, it has a certain surface area bearing on the rotor. Seems like no matter what, the dual Pistons just get more contact.
But at a huge cost for the DIY'er...
__________________
StackCovers.com
DieselJunk.com
DZLJIM.com
  #4 (permalink)
Old 06-26-2009, 11:25 AM
Talyn's Avatar
1994 Ford F-250
I'd go with the duals, honestly.
I can get a set easily where i'm located though.
__________________
  #5 (permalink)
Old 06-26-2009, 03:32 PM
DZL JIM's Avatar
FTE Sponsor
The SD dual piston calipers aren't too bad from the parts store, but you still need to find the 'pad cage' or whatever it's called, and those aren't available to buy (parts store or Ford). When you replace the caliper, you use your old one. There lies the main problem.
And none of the yards anywhere around here (or elsewhere that I've checked) have the calipers, or SD axle, or won't seperate the brakes from the axle...
So I'm kind of stuck with the Chevy calipers...for now...
__________________
StackCovers.com
DieselJunk.com
DZLJIM.com
  #6 (permalink)
Old 06-26-2009, 10:26 PM
c00nhunterjoe's Avatar
c00nhunterjoe c00nhunterjoe is offline
c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE. c00nhunterjoe has a very good reputation on FTE.
here is what i used from advance auto-
Wearever rotors---------YH145251 - $57.99 each
wearever silver pads- --- NAD-52 -- $14.99
Cardone calipers rt side-- 184124---- $17.99+$15.00 core
cardone calipers Lt side-- 184125----$17.99+$15.00 core
True torq ft hoses ------- H98925---$32.99 each
Caliper hose bolt(help isle) 13940----$4.28 each
so i am using the smaller ones. i can tell you that on my 33's and 35's the truck will lock the tires if you really stand on it hard. up to 100 mph it will throw you into the dash. i would not hesitate using them on a drag truck. its a dam front brake caliper workign on the rear of a truck. you cant go wrong
__________________
The name's Joe. I blow sheet up for a living, then get paid to fix it, and blow it up again.
http://www.youtube.com/user/c00nhunterjoe
http://community.webshots.com/user/c00nhunterjoe
  #7 (permalink)
Old 06-26-2009, 10:31 PM
crzycrazycarl's Avatar
crzycrazycarl crzycrazycarl is offline
crzycrazycarl is starting off with a positive reputation.
joe, do they have emergency brakes,,,wait its a front caliper. do you have a e brake?
__________________
97 F-250 Stroker, 6 inch stacks, Ts 6 pos chip, icp mod, boost gauge, 285/75's, K&N soon to go, fog lights, KC Grill lights
79 F 150 10" lift
  #8 (permalink)
Old 06-27-2009, 01:08 AM
Talyn's Avatar
1994 Ford F-250
Yes, do tell. No ebrake kinda screws it for me.
__________________
  #9 (permalink)
Old 06-27-2009, 07:16 AM
DZL JIM's Avatar
FTE Sponsor
Joe,
I used that exact list from an old thread, but at Autozone since that's what we have here. Most of the parts had to be ordered, I hope to tear into it on Monday.
I hate re-doing things which is why I looked into the SD calipers, but for the cost I can't beat the Chevy truck mod. And your input is encouraging!
As for the e-brake, this appears to be the best thing I've found so far:
http://stak4x4.com/Accessories/parking_brake.htm.
But it's for 4x4 trucks with a T-case, won't work with 2wd and slip yoke.
Don't hesitate to use a driveshaft brake. think about it, that it requires 3.55 - 4.10 less force to stop the drive shaft than the wheels, so the brake can be much smaller there.
__________________
StackCovers.com
DieselJunk.com
DZLJIM.com
  #10 (permalink)
Old 06-27-2009, 02:03 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is gaining momentum as a positive member of FTE.
The loaded front calipers from Ford come with the bracket. Pre assembled with pads. They were available last fall anyways.
__________________
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab (stock)
1986 F250 6.9 XLT Gone but not forgotten
  #11 (permalink)
Old 06-27-2009, 05:09 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
Fisher of Men
tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE. tjbeggs has a great reputation on FTE.
Jim the chevy pads are smaller than the SD rear pads and this is compounded by the fact that you don't get full contact of the Chevy pads on the rotor. I don't have any numbers for you but I know this first hand.
The SD parts are more $$ but they also fit better if mounted well. Also the Napa parts I use all the time now come with the mounting bracket when you buy the caliper.
__________________
Tim
1997 F-350 CC 4x4 PSD Auto 260K
I will keep My Money, My Guns, My home and My Family. YOU KEEP YOUR CHANGE!!
  #12 (permalink)
Old 06-27-2009, 10:27 PM
the chevy calipers dont have a p-brake, but the caddy calipers do, i am putting a driveline brake on mine whenever i get around to it
__________________
  #13 (permalink)
Old 06-28-2009, 08:17 AM
DZL JIM's Avatar
FTE Sponsor
Great info, thanks guys!
I was also told about the brake pressure limit valve on the master cylinder, never knew what that was. By eliminating that valve I should get full flow to the rear breaks, whereas with the valve it was limiting the drums pressure.
I love talking to idiots at the parts stores who don't know what they are talking about...
Any idea what the difference is between rear calipers for the SD "To 12/20/99" and "From 12/20/99" ???
Other than about $35 each??
Edit: Actually, the fronts look to be cheaper than the rears, might as well go with them, as long as they fit the rotors...
__________________
StackCovers.com
DieselJunk.com
DZLJIM.com
  #14 (permalink)
Old 06-28-2009, 08:26 AM
Talyn's Avatar
1994 Ford F-250
Well, with the ford light ass end syndrome. I wouldn't want full power to the rears, atleast on the drums. I could lock my 150's rear brakes all day. Could be interesting if you wanted to power slide.
The new tires hooked up better, so they wouldn't always lock up, but I have on gravel.
__________________
  #15 (permalink)
Old 06-28-2009, 08:36 AM
DZL JIM's Avatar
FTE Sponsor
Yeah, I wouldn't do it on a driver, but to hold rears for spooling up it should help...
__________________
StackCovers.com
DieselJunk.com
DZLJIM.com
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
