Any one thinking, why don't we use F450 OBS rear disc brake set up, they are 10 lug. If you put every thing together with 8 lug rotors with the right offset of the hat, it may work. They don't have the E-brake in the hat of the rotor. I think it is a drive line brake. Also on my 88' F350 DWR with rear disc and F450 master cylinder, I did not install the limit valve in the cylinder and it will lock up the rear brakes, but I would think the rear ABS on later trucks would not them lock up.
