Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 07-03-2009, 08:49 PM
hijo202 hijo202 is offline
hijo202 is starting off with a positive reputation.
Subscribed
  #32 (permalink)
Old 07-07-2009, 10:16 AM
bud48fla bud48fla is offline
bud48fla is starting off with a positive reputation.
I got every thing off of a 2000 G350 Van rear diff from the local drive line place. for $100.00. Cut mounting brackets off axle tubes and made new ones. Rebuilt the calipers and every thing installed without a problem. Rotors are still 8X6.5 on the Van. Larry
  #33 (permalink)
Old 07-07-2009, 11:33 AM
Larry, did the calipers have parking brakes? Or did you use a driveline brake? Or did you not worry about them? I am wanting to do a disc conversion, but do not want to use the eldorado calipers, and am not getting far on a driveline brake for 4x4. Thanks for the input.
  #34 (permalink)
Old 07-07-2009, 12:09 PM
Yes, they do have E-brake and yes I did use them.
  #35 (permalink)
Old 07-07-2009, 12:10 PM
wildstang wildstang is offline
wildstang is starting off with a positive reputation.
bud48fla, do you have any picts of your set up? Did you make the brackets from scratch or did you have some one machine them for you?
__________________
Jim-1996 F250 CC Shorty 4X4 E4OD 7.3L Diesel
Mods: 6637 air filter,203 F t-stat from Diesel Site-finally heat! HPX line, Tymar 3-4 dp to 4" exhaust, E4OD "The Cure" 30K mod for now, 140IDM mod, ISSPRO ev1 egt, trans temp, boost
Powerstroke - IF your not being blown, your just sucking.
  #36 (permalink)
Old 07-07-2009, 12:17 PM
Thanks for the quick reply Larry. I am also wondering about the brackets as well. Do you have a template that you created or did you just make them without. Just asking, so we don't have to re-invent the wheel (bracket) since you already have it working...
Thanks for the info on these. I will be looking for the prices on the calipers/used axle.
Mark
  #37 (permalink)
Old 07-07-2009, 04:35 PM
A freind of mine has a shop at his house. He took one of the backing plates home with him, with the dimension of the housing (whitch is smaller than the rear in the Van) and made them.
  #38 (permalink)
Old 07-08-2009, 09:53 AM
Is it possible to get a picture of the brackets, even from the back side would be good. Thanks.
__________________
  #39 (permalink)
Old 07-08-2009, 11:07 AM
http://www.fordmann.com/F350.rear_disc_brakes.htm Here is a site that will show some good pictures of the install. Larry
  #40 (permalink)
Old 07-08-2009, 11:53 AM
Thanks bud48fla, that is a very good article.
__________________
  #41 (permalink)
Old 07-08-2009, 06:34 PM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is online now
Adrenaline Junky
Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE. Cuda_jim has a great reputation on FTE.
Quote:
Interesting link, but I gotta ask why? That costs more than a bolt on kit and took many many hours of fab work.
Am I missing something?
__________________
Horsepower = How fast you hit the wall.
Torque = How far you take the wall with you.
They say if you play a Microsoft CD backwards you hear scary messages.
Even scarier......if you play it forwards it installs Windows
  #42 (permalink)
Old 07-08-2009, 07:19 PM
The hardest part of the whole project is making the brackets to weld on to and removal of the old brackets. We installed and was driving the truck about four hour's later. It really has to do with if you know someone with a machine shop or some one reasonable and have every thing together and thought out when you start the job. The only thing I purchased was Caliper rebuild kits and a spring kit for the E-brake from Advance Auto Parts to get the one set of springs to match the ones already on the E-brakes, that use have to change It was not a hard job at all. I also have done a rear disc brake on another truck I had and did the Chevy Caliper and Disc set up, but I took the Caliper mounting plate from the front of a 74' Chevy 3/4 ton 4w/d and welded up the holes in it, redrilled the holes and bolted up. I like the Van set up a lot better. It looks like the truck came with it.
  #43 (permalink)
Old 07-08-2009, 07:53 PM
Cuda_jim's Avatar
Adrenaline Junky
Nice job but...That link said it cost $867.05 total...the kit is only $709.....
__________________
  #44 (permalink)
Old 07-08-2009, 08:16 PM
If you read, this guy purchased the rear end complete from a wrecking yard from a Van, then purchased almost every thing new or rebuilt. He didn't use hardly any of the items he got from the wrecking yard. The kit you are talking about, doesn't look factory for a Ford Truck. The Van set up does look factory.
  #45 (permalink)
Old 07-09-2009, 08:10 AM
DZL JIM's Avatar
DZL JIM DZL JIM is online now
FTE Sponsor
DZL JIM is gaining momentum as a positive member of FTE.
That link shows Part 1.
Are there more parts?
I'd love to see more pics!
__________________
'96 F-350 Reg Cab 4x4 PSD
'97 F-350 CC Short Bed 4x4 PSD
StackCovers.com
DieselJunk.com
DZLJIM.com
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
