Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-25-2009, 01:33 AM
65f100CoryE. 65f100CoryE. is offline
65f100CoryE. is starting off with a positive reputation.
Sorry Guys another VIN Plate decode
want to find out what I will be workin with here goes.
#F25YCE02333
I get F25 is F250 (3/4ton)
Y = 360 2bbl C is oakville ontario Canada and ther consecutive number etc I want to get the rest of the info
Color E
model F254
Body K 81
Trans G
Axle 38
? I am not sure what the trans and axle deal is. would it be a C4 behind a 360? and rear ratio not sure.
__________________
Cory
65F100 390 4spd ported heads, comp XE-274 cam, edel RPM intake, headers.
66F100 460 C6 headers and mild cam
69F250 360 C6 Auto
74 Maverick 2door 302 C4 Auto Comp XE-262 cam
  #2 (permalink)
Old 06-25-2009, 11:18 AM
MotorDog's Avatar
MotorDog MotorDog is offline
MotorDog is starting off with a positive reputation.
S/N De-Coding.....
You're right so far. Your truck was manufactured in September of 1968, making it an "early" built 1969 model. The Color "E" means your truck was originally painted "Sky View Blue," which was a light blue and quite popular. The Model Number F-254 means your truck has a GVW rating of 6,900 lbs. The "G" for the transmission code indicates only that it is an "automatic" and could be either the C-4 or C-6. More than likely, it is a C-6. You can check it out easily by crawling under and looking at the transmission pan. If it is square, it is a C-4. If it a square shape but one of the corners is notched out, (like a map of the State of Utah), it is a C-6. The Axel code of 38 indicates your differential is a Dana 60 with a non-locking ratio of 3.73 to 1. Great for pulling and still gives a measure of fuel economy at highway speeds. The "K 81" indicates your truck came with a Dark Blue interior and is a Conventional Cab truck. Hope this helps!
  #3 (permalink)
Old 06-25-2009, 02:32 PM
cool that is what I was looking for. I was hoping for a locking rear since this one is plastered with camper special logos on it etc. yes I can easily identify the transmission. I didn't think C4 came behind an FE tho. I will look when I bring it home. thanks. is there a good site where this info is available that I would't have to keep posting on here etc. not that this isn't helpful I just like to have the resources for myself as well.
__________________
Cory
69F250 360 C6 Auto
  #4 (permalink)
Old 07-03-2009, 10:29 AM
MotorDog's Avatar
VIN Info.............
You might do a web search for 67 to 72 Ford trucks and see what you find. I've been told there are several different sites which have something to do with these old trucks. Good Luck!
  #5 (permalink)
Old 07-03-2009, 12:13 PM
Madathlon's Avatar
Madathlon Madathlon is offline
Madathlon is starting off with a positive reputation.
Yes, BUT you will always find the best help here. I have even in the past had memeber travel to my home to help. and I live Hours away from any towns. The member here not only have good info, they make great friends
Quote:
__________________
If it ante broken dont fix it.. If it is.. hit it with the biggest hammer U can find :P
  #6 (permalink)
Old 07-04-2009, 09:45 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Originally Posted by 65f100CoryE. View Post
F25YCE02333
Color E
Model F254
Body K81
Trans G
Axle 38
F25 = F250 2WD
Y = 360 2V
C = Ontario Canada Assembly Plant
E02333 = 1969
E = Sky View Blue
F254 = F250 2WD / 6900 lbs. Gross Vehicle Weight Rating
K81: K = Dark Blue Corinthian Vinyl & Dark Blue Granada Pattern Vinyl // 81 = 81B Custom Cab
G = C6 Cruise-O-Matic *
38 = Dana 60 / 3.73-1 / non Limited Slip / 5200 lb. Rear Axle Capacity
* Thru 1978, Ford used the G A/T trans code for everything!
One has to know which A/T came with which engine.
1965/67 F100/350's with 352's used the MX Cruise-O-Matic.
1968/76 F100/350's with 360/390's used the C6 Cruise-O-Matic.
NO FE engine ever used a C4!
Note: Just because the truck was assembled in Canada, does not mean it was only sold in Canada.
Canadian built trucks were sold throughtout the USA. Most, if not all the 1967/72 Crew Cabs were assembled in Canada.
MotorDog: All the above info was decoded using the 1964/72 FORD TRUCK PARTS CATALOG.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #7 (permalink)
Old 07-05-2009, 10:48 PM
MotorDog's Avatar
Yes............
AND, your point IS???
  #8 (permalink)
Old 07-06-2009, 01:17 AM
Ford Parts Guru
This is the point I was making, the Ford truck parts catalog is the best source of info.
I've decoded well over 700 VIN's and Warranty Plates for members of FTE.
I've seen some of the other so-called VIN decoder sites. IMO, they aren't worth TWO CENTS!
__________________
  #9 (permalink)
Old 07-06-2009, 10:27 AM
MotorDog's Avatar
The Point.........
I'm still not sure why your posted info was directed at me. As far as your personal record of "decoding VIN's," there wasn't any comment regarding that because no one knew scores were being kept. You can be the self proclaimed Winner and Champion if you want to be! So, you have a great library......many folks enjoy that advantage by your willingness to share. If you are offended when someone else tries to help someone else out, all I can say about that is "too bad." Personally, I have no objections to you decoding as many VIN's as you can or want to, or even all of them for that matter. Regarding other sites, I believe in "live and let live." There is information that is valuable in many places.....not just from your posts. Anyone that limits their search for knowledge to only one source may be selling themselves short. You apparently failed to notice that I neither recommended any particular site, nor did I mention any one by name just from common courtesy to this site. If all of the other sites are what you believe they are, then you also have the choice of not going there or participating with them. They won't miss you. As far as starting an argument with me, you are wasting your time and mine. I would not gain anything by exchanging rhetoric with you and don't want to. Therefore, I won't bother adding comments to anything you post and would respect the same from you in return. Even if my Dad is bigger than your Dad, there is no point in chasing the issue. Have a Great Day!
  #10 (permalink)
Old 07-06-2009, 05:00 PM
Ford Parts Guru
I'm on FIVE other sites, under another name.
All I was trying to do was let you know where my VIN decoding info comes from.
Too put it mildly, I'm not the easiest person to get along with. I meant nothing personal...since you appear to have taken what I typed as such, I apologize.
__________________
  #11 (permalink)
Old 07-06-2009, 05:16 PM
MotorDog's Avatar
Apology............
Accepted! My hair, (what I have left), has been known to ruffle quickly, also. Therefore, I also apologize for any of my comments which might have caused you any offense. That was not my intention, either. Have a Great Week!
  #12 (permalink)
Old 07-06-2009, 05:53 PM
Ford Parts Guru
Pushing 65, I still have all my hair, the rest of me is falling apart.
btw, I'm LDS.
__________________
Tags
12 , 1972 , 1978 , 1979 , 72 , canada , decode , decoder , f100 , ford , galaxie , number , oakville , ontario , truck , vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
