Go Back   Ford Truck Enthusiasts Forums > Misc. > Fuel Injection, Carburetion and Fuel System
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-25-2009, 01:28 AM
Reed Reed is offline
Reed is starting off with a positive reputation.
Speed density to MAF swap, how to fix the air intake?
I have gathered nearly all the parts to swap the speed density injection system on my 302 powered 89 E-150 to a MAF system off a 93 Mustang GT. I say nearly all because i am still trying to figure out a way to adapt the dual inlet throttle body on the SD system to the single hose MAF plumbing.
I have seen the slick factory piece used in 95-96 trucks, but have had no luck finding one. Anybody have a cheap method of going from dual air intake tubes down to the single?
Thanks.
  #2 (permalink)
Old 06-28-2009, 01:43 AM
DasCheckers's Avatar
DasCheckers DasCheckers is offline
Montana, fool.
1993 Ford F-150
DasCheckers has a good reputation on FTE. DasCheckers has a good reputation on FTE.
I'm gonna snorkel mine and don't want to run dual snorkels so I'm all ears as well!
__________________
Stoney | Montana Chapter Leader of FTE
Live in Montana? Come join The Montana Chapter,
1993 Ford F150 XLT 4x4 5.0 5spd with a Fresh Rebuild
Write your congressman!
  #3 (permalink)
Old 06-28-2009, 01:48 AM
I am going to see if I can't just make an adapter out of aluminium to mount the Mustang throttle body on the van upper intake plenum. Probably won't be optimal for high RPM airflow but this motor never sees the high side of 3k RPM.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
