I worked at a mini truck wrecking yard in California back in 85 to 87 I think. I had to take them damn things out quite a bit. The rear window was the easiest way back then. But it can be done by taking all the seats, and center console out. Tip it toward the passanger side, then then angle it toward the passanger door. It should come out real easy. It's better to have someone help through the drivers door once you have it tipped just to guide it through the passanger door.
The head liner isn't card board, it's actually a thin hard white foam of some sort. If you get a crease in it, it will probably show through what ever you cover it with.
__________________
92 F-150 flairside all stock 5.0 auto 2WD
93 F-250 4x4 flatbed 5.8 auto KnN, throttle body spacer, underdrive pulleys, flowmaster
73 Jeep CJ5 springover axles, reversed front shackles, 304, T-18, lockers front/rear, 4:29 gears, 33s
87 Toyota Tercel Tuner some engine mods exhaust
