You'll have to transfer over everything (engine wiring harness, computer, etc.), including fuel system (pumps, tank, lines, etc) as the EFI engine has a higher-pressure fuel system. I can't remember if the motor and transmission mounts are 100% interchangeable, but the distance between frame rails is the same on both. Hope this helps.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
