74 Ford F100 w/ 360 lost spark last night
I was driving the truck around the block and when driving up a hill the truck died. I checked everything and it looked fine but when I tried to start it "no go." I finally checked the spark and I have no spark.
Not sure what happened or where to begin.
Thanks in advance for your advice,
Craig
Craig
I'm not sure what you meant by "check everything." When diagnosing a no-start issue, being specific is very important.
Try the following test: with the coil connected, connect a test light from the TACH TEST post of the coil down to engine ground. Use the key to crank the engine over, and the light should BLINK. Report your results and we will go from there.
Do not replace anything until you have solid, objective proof that the part is actually bad.
If the light is not blinking, the module is not firing the coil. This means one of several things:
1. The module is not getting a signal from the distributor to fire the coil.
2. The module is getting a signal, but not doing anything with it.
3. The module does not have power.
4. The coil does not have power.
Let's start with number one. Disconnect the distributor connector, and use a multimeter to measure the resistance between the ORANGE and PURPLE wires on the distributor part of the connector. It should be between 400 and 700 ohms.
tjs_79ford
09-20-2009 11:30 AM
Craig
02-03-2001 12:43 AM
