Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-24-2009, 11:07 PM
Haydelhunter Haydelhunter is offline
Haydelhunter is starting off with a positive reputation.
f-150 supercharged OVERHEAT
hey guys i need some help. i have an 01' supercrew with a magnuson supercharger on my triton 5.4 turning about 4-5 lbs of boost. heres the problem... my truck is overheating at idle on really hot days and when im riding around town. as long as im on the road doing over 40 or 50 i never have this problem. i installed a high performance radiator and heat exchanger (lighting upgrades from lightning force performance) at the end of last summer and im still having problems. last week i put a 160 degree thermostat and i think its makin things worse. i just got off the phone with a guy from magnuson and he thinks i need to get my engine dynoed and retuned cuz he thinks i may be running too lean.. im hoping some of you experienced guys can kinda point me in the right direction. id hate to burn this thing up or blow a head gasket. i really need to cool this puppy down. i want this thing to idle all damn day with the ac on high and not have any trouble with overheating. help me out please. thanks
  #2 (permalink)
Old 06-25-2009, 03:54 PM
Lazy K Lazy K is online now
Lazy K is gaining momentum as a positive member of FTE.
My thoughts would be to look at the cooling fan. I assume it is a viscous fan? With the engine cold and turning the fan by hand there should be a drag.
  #3 (permalink)
Old 06-25-2009, 07:48 PM
its an electric fan. and it turns very easy by hand when the engine is off. its wired directly to my ignition, because a few summers ago i was having trouble with the thermostat on the fan so i had it wired directly to my ignition. when my ignition is on the fan is on. and iv been told its a very efficient fan. i just dont know any of the specs on it or what brand it is
  #4 (permalink)
Old 06-26-2009, 11:00 AM
It still sounds like you have insufficent air flow through the rad at idle.
However it might be worth getting the ignition timing checked.
  #5 (permalink)
Old 06-27-2009, 06:55 AM
Catmonkey Catmonkey is offline
Catmonkey is starting off with a positive reputation.
If it's only overheating at idle, I doubt it your tune. You might want to check your settings on your fan to see when (and if) it's coming on. How many fans and what size are they. Do you have air conditioning? Is your fan set up such that when the compressor is running the fan is running?
__________________
2008 F-150 Lariat SuperCrew 4x4
  #6 (permalink)
Old 07-01-2009, 02:54 AM
Don S.'s Avatar
Don S. Don S. is offline
1978 Ford F-150
Don S. is starting off with a positive reputation.
Where is your intercooler and what size is it?
Do you even have an intercooler?
Has it always ran hot?
If not what have you done prior to it running hot?
__________________
Committee: a group of the unwilling, picked from the unfit, to do the unnecessary.
"Brutus" 1978 F-150 SC 4x4 BB460
" There is a very fine line between "hobby" and "mental illness."
" -Dave Barry, Nationally Syndicated Columnist
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
