rear axle vent tube - Ford Truck Enthusiasts Forums
rear axle vent tube
Old 06-24-2009, 09:39 PM
30287f250 30287f250 is offline
30287f250 is starting off with a positive reputation.
rear axle vent tube
I bought an 87 F250 last night and when I came home from work today I found a good size puddle near the drivers side rear wheel. I looked at it seems that a hose that is not connected to anything, but has a plug on the end of it split open near the fitting on the rear axle. This hose connects into the rear end where the brake lines do but the other end is just plugged. Is this the vent tube and should it be plugged or leaking any kind of fluid. The tube is about 6" long and is split open right near where it plugs in the rear end. What should I do with this as far as fixing it? Any help is appreciated. thanks
Old 06-25-2009, 12:49 AM
IreallyLikeFords's Avatar
IreallyLikeFords IreallyLikeFords is offline
IreallyLikeFords is starting off with a positive reputation.
Hey this hose just vents air from the rear axle. the end is plugged so mud doesnt get in it and clog it. If you notice, its not completely plugged, air can still get through.
Mine did the same thing. Just get a new piece of hose or cut it back to where its not split and reattach it. I put a hose clamp on mine so it wouldnt split again.
I dunno about the puddle though. Was it gear oil or brake fluid?
Old 06-25-2009, 08:19 AM
It appears to be gear oil from the rear, is it normal for it to be going through the vent tube like that. I just bought the truck and havent pulled the rear diff. cover off yet to look at its condition but I drove it an hour home on the highway and didnt feel any problems or anything out of the ordinary. It was a good amount that came out of the tube.
Old 06-25-2009, 09:33 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Do not recall seeing any plug in the end of any, it clips on up on the frame pointing to the rear. Maybe a bug made his home in the end.
The rear end needs to be vented or the seals can go bad and start leaking.
If the split is low enough or the hose is not attached then yes oil can come out of the hose.
Also check the oil level in the rear end to see if it is too full or low.
Old 06-25-2009, 10:10 AM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Quote:
My '87 has a little check valve or breather on the end of the hose.
I agree with everything else. Replace the hose and check the fluid level.
I used a cow hitch of .040" safety wire to hold it onto the hollow junction block bolt.
Valve on Rear Axle Tube 1966 F250 66F250CS 1961 - 1966 F-100 & Larger F-Series Trucks 9 08-27-2015 02:13 PM
'53 F250 split hypoid rear axle DumbLuck 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 01-28-2015 05:09 AM
Rear differential vent hose broke Pigman54 1999 - 2003 7.3L Power Stroke Diesel 7 07-22-2014 11:20 AM
98 F150 2WD: Rear axle vent tube blowing oil fitz1898 1997 - 2003 F150 13 03-24-2014 09:25 PM
Rubber fuel hose alchemist1 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-24-2011 12:24 PM
Tags
2004, axle, block, brake, connected, differential, end, f150, ford, hoses, rear, replace, truck, tube, vent
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
