64 292v8 Swap
64 292v8 Swap
What size/ type of ford motor can I use to replace the stock 292 in my truck now. I'd like to do as little modification as possible but I'd really like to see big power from the new motor (450-500hp) The truck is a 64 F250 and I'd love to retain the stock 4 speed. Any suggestions or articles?
There are tons of aftermarket brackets to install The 352 through 428, The 429/460s, 289/302/351W/351M400 and 351C, There are even mounts to install Mouse and Rat Chevrolet's. Aftermarket mounts are also made to add after 65 tail shaft mounted transmissions form ford or GM.
They run from simple bolt in to weld in.
Basically the 61 to 64s open front frame area and space allows all kinds of swaps.
I have a 472 EFI Ford in my 64 with a C6.
Garbz
Garbz
Not that familiar with the 292, may be surprized what you can do with it. Just rec'd the July 09 issue of Hemmings Muscle Machines magazine, there's another article in the Jan. 09, issue where they get into the E and F code Y block configurations. The articles were on a 57 Ranchwagon, and 57 Ford Custom, anyhow, thought they were interesting.
400 horse on a 292 = about 15K in cash.....
? JimKoz the aluminum bell offered? Is the bell a cross member mount type?
Sponsors of this site have the mounts.
http://www.carolina-classics.com/ Give Ricky a call..
Garbz
Garbz
You can turn 250HP out of a 292 fairly easy. Lots of tuning though. A Premium rebuild is gona cost you about 5K. About A grand on induction. A grand in an exhaust. About 500 for a good ignition.
250HP is quite a bit in a pickup. A 90s 5.0 mustang only had 225. Plus the sound of a Y is to die for. Throw it in third at 35 somtime. Makes people look.
Why would you want to do that? Use a Chevy motor OR a T98? Unless you just happen to have both laying around. I'm assuming you are asking about an adapter and/or motor mounts? An adapter for either is going to be expensive. Why not use a transmission that will bolt up to the 400 if that's what you have, though (from what I understand) I don't think the 400 is a wonderful engine???
No the 351M/400 uses the small block perch and engine insulator. 351C uses the same.
Only similarity between the 351M/400 and the 429/460 is the big block bell housing bolt pattern.
The 351C uses the small block 302/300I6 pattern for bell housings.
Garbz
