Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-24-2009, 08:02 PM
teg2_nv teg2_nv is offline
teg2_nv is starting off with a positive reputation.
2000 7.3L Super Duty - AC Clutch Slipping
Yesterday my A/C stopped working. Took a look under the hood and noticed a squealing coming from the a/c clutch.
When A/C is on and clutch is engaged the compressor spins some times but is accompanied by a squeal and is definitely slipping. I checked the air gap and it is very small under 0.35"" the magnets (or what looks to be magnets) on the clutch hub are worn down. I took the pulley off and removed the last spacer that was inside and bolted it back on. It then had virtually no air gap. The compressor ran and the ac worked perfectly except that the clutch would not disengage.
What should I replace? The entire compressor with new clutch? The clutch assembly or just specific parts. I really do not want to have to evacuate and recharge the refrigerant if I don't have to.
Could the compressor be faulty causing the clutch to slip?
__________________
2000 F-350 DRW 7.3l CC SB Lariat Le 4.10LS 4x4
  #2 (permalink)
Old 06-24-2009, 10:08 PM
2000Ford2000's Avatar
2000Ford2000 2000Ford2000 is offline
2000Ford2000 is starting off with a positive reputation.
I vote clutch.
__________________
2000 E-150 Jayco Conversion (5.4)
1989 E-150 Conversion (5.0)
-previous Fords
1989 E-150 Trans-Aire (5.0)
1988 E-350 26' Jayco RV (7.5)
B.C. (Before Children)
1991 Escort (1.9)
1982 Capri (2.3)
1971 Pinto (2.0)
  #3 (permalink)
Old 06-25-2009, 08:10 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE. projectSHO89 has a good reputation on FTE.
All you need is a new new clutch plate. Reinstall the previously removed shim when you install the new plate.
I'd recommend a Motorcraft part only.
__________________
If your original owner's manual is missing, download a soft copy from www.fleet.ford.com under the MAINTENANCE tab.
Think about it: Ignorance can be addressed through education but you can't fix stupid! ...apologies to Ron White
  #4 (permalink)
Old 06-26-2009, 10:36 PM
What causes the clutch plate to wear? Could the pulley or bearing be bad?
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
