transmission fluid capacity
06-24-2009, 05:06 PM
on
does any one know how much fluid goes into to a 1990 f250 5.8 4x4 transmission
06-24-2009, 07:55 PM
as per my manual:
c-6 shallow pan= 5 qt (US)
c-6 deep pan = 6qt (US)
e4od--------- = 8.5 qt (US)
manual transmission = 4.5 to 7.6 pt (US) depending on the tranny
I believe all manual transmissions get filled to the fill plug though... someone correct me if I'm wrong
06-24-2009, 08:29 PM
on
Quote:
Originally Posted by
goodB0Y
as per my manual:
no man your right
06-24-2009, 09:50 PM
on
The manual says 7.6pts for a manual M5OD R2, but i found that using the whole 2 quarts (minus a little spillage) was much better. At 7.6pts, the tranny wouldnt shift into any gear at stand still. I had to turn off the engine. I topped it off by parking on a hill, and now it shifts.
06-24-2009, 09:57 PM
on
Those figures have to be if you only drain the pan and not the converter. A C-6 from dry fill is something like 13 qts to fill it completely with the deep pan.
06-25-2009, 12:15 AM
on
Sorry, typo on my last post, go up two replies. Obviously I meant 4 quarts (not 2 quarts) since 8 pints = 4 quarts.
06-25-2009, 07:12 AM
on
I just did my E4OD and I used just under 18 quarts. I did drain the TC.
Hope this helps
CS45
06-26-2009, 10:28 AM
on
I used 4+ gallons in a dry E4OD Cost me more in tranny fluid for a day than gas did a 4$ a gallon
Jay Hyde
1999 to 2016 Super Duty
12-21-2016 10:58 AM
1972fordhighboy2
13
04-14-2016 07:39 PM
kcoburn1
08-07-2015 04:56 AM
CollinsCD
12-05-2013 05:52 AM
smitty403
12-08-2010 04:26 AM
1991 ,
1996 ,
2008 ,
30l ,
70 ,
capacity ,
f250 ,
fluid ,
fnr5 ,
ford ,
fusion ,
quarts ,
tranny ,
transmission ,
truck
