Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-24-2009, 03:04 PM
gdw3138 gdw3138 is offline
gdw3138 is starting off with a positive reputation.
fuel reset solutions
Are there any common solutions as to why the fuel pumps need to be reset? The BII is a 1988 with 2.9 engine. The BII was driving fine, making a slight left turn, slight downgrade when fuel system quit. Are the problems related to high resistence on the electrical connections due to corrosion on electrical connectors, clogged filters leading to high pump demand to maintain pressure leading to higher loads, just worn out pumps, ....???
When I found about reset button and reset the circuit, the BII started up easily.
Thanks
  #2 (permalink)
Old 06-24-2009, 06:40 PM
mrshorty mrshorty is offline
mrshorty is starting off with a positive reputation.
I assume you are refering to the inertia switch on the floorboard next to the transmission hump. It's been a long time since I've read up on the specifics, but there's a ball bearing in there and a magnet. If memory serves, when it feels a sufficient jolt (from an accident), the ball bearing does something to break the fuel pump circuit.
It's not common, but I have heard of a few cases where that mechanism wears out, and allows the switch to trip under much smaller jolts. Replacing theswitch would fix this sort of problem.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
  #3 (permalink)
Old 06-24-2009, 09:59 PM
Thanks, I did not know that this was an inertia switch.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
