MA Archived Buy/Sell/Trade Ads - Page 2 - Ford Truck Enthusiasts Forums
Massachusetts Chapter Join Chapter, Leader: donjamer
Closed Thread
Old 12-27-2009, 02:56 PM
GUNNERDOG's Avatar
GUNNERDOG GUNNERDOG is offline
GUNNERDOG has a very good reputation on FTE.GUNNERDOG has a very good reputation on FTE.GUNNERDOG has a very good reputation on FTE.GUNNERDOG has a very good reputation on FTE.
Sorry, all my stuff is gone.
Old 12-27-2009, 05:00 PM
Black X Black X is offline
Black X is starting off with a positive reputation.
ok thank you
Old 02-25-2010, 04:34 PM
mattystowe's Avatar
mattystowe mattystowe is offline
mattystowe is starting off with a positive reputation.
found this on Craigslist may be of interest to someone around here..
1986 Ford F150 4X4 mudder
Old 03-05-2010, 03:12 PM
shane1447 shane1447 is offline
shane1447 is starting off with a positive reputation.
Hello all. im selling my 77 F250 custom 4x4 auto with plow. ~$2000. already wrote a book about it in the classifieds, so i'll link to that! pics soon. gotta get my cam back from my sis, lol.
http://www.ford-trucks.com/forums/93...der-tires.html
price may be negotiable.
thanks for lookin!
Old 04-24-2010, 05:13 PM
EricJ EricJ is online now
EricJ is gaining momentum as a positive member of FTE.EricJ is gaining momentum as a positive member of FTE.
352 up for grabs
Just swapped out my 352, I don't need it and have no room to store it, so anyone that needs it can have it if they can come and get it. In Mass. on Cape Cod. email me at capecanal@comcast.net
Old 04-27-2010, 08:34 PM
c4barnes c4barnes is offline
c4barnes is gaining momentum as a positive member of FTE.c4barnes is gaining momentum as a positive member of FTE.
Hi all, have some Dennis Carpenter floor pans and cab mounts for sale for the best reasonable offer. PM if interested.
Old 05-22-2010, 01:13 AM
70torino429's Avatar
70torino429 70torino429 is offline
70torino429 is starting off with a positive reputation.
Selling my 91 F150. I hate to sell it since I've put so much time and money into it over the years, but I can't finish this project after recently screwing my hand up pretty bad.
basic details-
truck has 157k on it, though the 302 engine has 66k on it. Runs pretty good, though the vacuum lines and wiring need a little work, though it does start and run/drive fine.
E40D trans, 2wd, 3.55 rear end.
Tires arent the best except for the right front which is almost new, but they all have some tread left and hold air.
all new brake lines and hoses throughout the entire truck, cross drilled front rotors with brand new pads and 1 new caliper.
new fuel injectors, throttle cable, heater hose, water pump.
body is pretty rough, needs paint, though not much rust, entire underbody is painted.
Cracked windshield
Fresh trans fluid + filter and rear trans seal.
Can give you bill of sale with it, though might be best for parts.. your call.
Asking 1k, but will listen to reasonable offers. Junkyard here will give me $500 for it the way it is, but would like to get a little more, and would rather not send the truck straight to the crusher if someone can use the parts. Pushbar in pic is no longer on the truck and not included unless you want it and the offer is right. If you want more pics PM me what you'd like to see a pic of. Located in Wilmington,MA
Old 07-06-2010, 06:48 AM
Ford Truck parts for sale - cleaning garage:
All parts USED unless otherwise specified. PM if interested.
- Metal dash for 73-79 $25
- Door shells for 73-79 $35 a piece
- vent window assemblies for 73-79 - $15 ea
- Side glass 73-79 - $10 SOLD
- Rear glass 73-79 (I'm told this will fit up thru 96, you just need the correct rubber seal). - $15
- '78 4x4 steering column (4 speed) - $40 SOLD
- '73 3 speed manual transmission - $25
- '73 302 intake and exhaust manifolds & 2 BBL carb. - $25
- '73 parking brake lever - $10
- Flexplate off ’91 302 truck motor - $25
- NEW ’73-’79 cab mounts DENNIS CARPENTER $50
-NEW ’73-’79 floor pans DENNIS CARPENTER $75
-89 302 roller block needs rebuild. $25
Old 07-06-2010, 10:34 AM
While we're at it, off an '86 crew cab I have:
- Headache rack SOLD
- 5th wheel tailgate SOLD
- Running boards. These are the old school Dee Zee type aluminum that go to the back of the cab. I do not have the piece that covers from the rear wheel to the front of the bed.
Everything is in good shape structurally; the headache rack has surface rust up top. Not the Massachusetts "surface rust", but real western surface rust that hasn't actually eaten all the metal. PM for photos if interested. $20 each.
Old 08-17-2010, 05:20 PM
barecove's Avatar
barecove barecove is offline
barecove is gaining momentum as a positive member of FTE.barecove is gaining momentum as a positive member of FTE.
20" KMC WHEELS FOR SALE
Truly innovative design, like no others!
Dramatically change the appearance and stance of your F-150 with a set of Matte Black Zero Rims by KMC Rims. KMC Wheels will not only look aggressive and unique on your truck, but will stay looking great for years to come. For maximum durability and longevity KMC Wheels are made from aluminum. KMC also provides a lifetime structural warranty on ALL of their wheels. Get rid of your boring rims and replace them with a set of Zero Wheels by KMC.
  • Aggressive appearance
  • Durable aluminum construction
  • Easy to clean and keep clean
  • Size 20x8.5
  • 6 Bolt pattern
Like new set of four.... was $800.00 NOW $700.00 cash... compare @ $350+ ea. new
Old 11-04-2010, 08:17 PM
LayBaks402's Avatar
LayBaks402 LayBaks402 is offline
LayBaks402 is starting off with a positive reputation.
Looking For Daily Driver.
Looking to see if anyone know someone in the mass area how is selling a 4 cylinder ranger. preferably late 90's to early 2000's. looking to spend around a grand. please give me any leads by emailing me. adam.bdsupply@gmail.com
Thanks a lot.
Old 12-14-2010, 05:04 PM
sexybluelady sexybluelady is offline
sexybluelady is starting off with a positive reputation.
well I'll give it a shot I have pair of apc racing seats that are tan, black and swede. They have sliders on them with brackets from off of late 80's to early mustang. I have text message pic's to who ever needs them. I'm asking 200 dollars for the pair, there dusty and dirty from sitting in my garage forever.
four one three, six two seven, six seven seven nine.
  #28
Old 07-12-2011, 08:42 AM
Rose Clifford's Avatar
Rose Clifford Rose Clifford is offline
Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.Rose Clifford has a great reputation on FTE.
I want a new tailgate! E1 or F4 (fire engine red) paint code
99-2011 will work, preferably a super-duty newer style with "SUPER DUTY" on the back.
I'm also on the market for a 2005 style chrome grill.
  #29
Old 09-10-2011, 10:27 PM
slowmans's Avatar
slowmans slowmans is offline
slowmans has a good reputation on FTE.slowmans has a good reputation on FTE.
I have a brand new Banks stainless steel exhaust system for 2008-2010 f-250/350 pickups brand new, never installed......looking to get $600 OBRO.
PM me if interested, I'm on the south shore MA
  #30
Old 12-05-2011, 05:21 PM
NewEnglander's Avatar
NewEnglander NewEnglander is offline
NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.NewEnglander has a very good reputation on FTE.
Im looking for some tires with some decent tread left.
I need atleast 2 matching tires that are 235/75/r15
Or a set of 31x10.5x15
Or a set of 32x11.5x15
Im in the Lowell area. Leave me a message with some details.
Closed Thread
5 Star Tuning aFe Header Group Buy on 48-43015-YN & 48-43015-YC fordmdb Vendor Specials, Discounts, Product Announcements & Group Buys 0 01-12-2016 01:29 PM
Any advantage to 4.9l intake tube? KineKilla 1987 - 1996 F150 & Larger F-Series Trucks 16 07-26-2015 11:57 AM
Head gasket replacement Duncansm Explorer, Sport Trac, Mountaineer & Aviator 1 07-01-2015 12:03 AM
2000 F-150 F-150 Mark 3.8 & 4.2L V6 1 03-23-2014 09:18 AM
oil buildup in intake????? ecolandscaping17 1999 to 2016 Super Duty 11 02-02-2014 08:18 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1995, bottom, classic, f150, for1200, ford, ma, mass, mi, plow, runs, sale, trade, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
