Leaf spring greasing/oiling
if your referring to rounding the ends , as well as chamfering it's all for one reason . i read an article years ago by pat ganahl in street rodder , where he did this to get rid of any probable edgea that could " dig into each other while they're flexing . for some reason that stuck in mt head and i've done it with anything on leaves that was something i cared about since . sh-- i think i'm showing my age talking 'bout pat ...........
Now, the first thing you need to do is to weigh down your F3 as much as you can. Fill the bed with bags of concrete, get all your fat buddys to stand on the front bumper, etc. Hit the spring packs with an angle grinder to remove all the grunge, paint, and crud. Now weld all the leaves together, You want a solid continuous bead here, no puny stitch welds. Do all edges and fronts of all leaves and, Viola!!! You are now the proud owner of your own custom made mono leaf spring. Enjoy the ride!!!
NO need to thank me, just being able to provide this helpful tip is thanks enough
Bobby
There is virtually no quality control testing done on those shocks except to check for obvious leakage. It's MUCH cheaper to replace a few returned shocks than to check tollerances and operation of all the shocks that the manufacturer is selling for < 10.00 per shock. Most faulty ones never come back because the average motorist has no idea how to tell if the shocks have gone bad and assume that since they were recently changed to a major brand they must be good and that's the way they are supposed to work.
There are a few manufacturers that cater to the knowlegable car guys (and gals) that can appreciate and demand a quality product, and are willing to pay for it. Koni, Bilstein, Penske are the 3 I am most familiar with. These are the manufacturers that even the car manufacturers turn to for their high performance models OEM units. All Solstices and Skys come from the factory with Bilstein shocks for example.
A quality shock is ~ 2X the price of a garbage shock, but it is definitely a case of you get what you pay for. Most of the price of the cheaper shocks goes for advertising and middlemen profits, not for what's in the box.
Hey -- I stepped up, these shocks were $20 apiece! You ought to check prices, if you can find Bilsteins for anything for less than $75 each, I'd be surprised. AFAIK they offer nothing for BonusBuilts. I've had good luck with KYB shocks/struts, which despite their name are made in the USA.
I agree about Gabriel/Monroe, they are still producing the shocks that were "OK" back in the early '60's when your Oldsmobile road-floater needed shocks. Can you blame them, tho? Probably 75% of car owners would pick a $10 shock over a $75 shock any day of the week.
Sorry, I thought HD off the self shocks were in the 30-60.00 range. To me even 125.00 per is a good deal for a high quality shock that's properly valved for each application instead of the one size fits everything... sorta... approach of the major brands.
20.00 each? That means the retailer paid ~ 12.00 each, the jobber paid ~ 8.00, they cost the manufacturer ~ 3.00 to make including 1.00 for the multicolor box. can you see the problem here? I knew that you could!
Considering the amount of money we all put into these kidney shakers, I would think that if it is one of those little things that improves the ride and handling, it would be worth the extra $200-$300!
Shoot I bought a pair of shoes that cost more than that once (but admittedly, that's a girl thing)!
#30
I can gaurantee your frame won't flex anywhere near 14" or even 1/4 that with everything mounted to it.
