Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-24-2009, 12:52 PM
Extacie Extacie is offline
Extacie is starting off with a positive reputation.
biggest tire possible with out problems
Hi, I have a 3/4th ton truck that I will be lifting soon and getting 33"s/35"s. Now, my mechanic said that putting bigger tires on vehicles is very hard on them. They way he explained it to me was he said take to 10ib potatoe bags and hold them in each hand and then hold your arms straight out with the bags in your hands.. That's what you are doing to your vehicle. Okay, so how hard is it on a truck with 33"s? What about 35"s? That is basically the only question I had.. I just don't want stuff to start messing up on my truck since I am getting the tires/lift mainly for looks.
  #2 (permalink)
Old 06-24-2009, 05:42 PM
guitarnik's Avatar
guitarnik guitarnik is offline
1990 Ford F-250
guitarnik is starting off with a positive reputation.
it does stress things a little more than stock but a lot of guys run larger tires with no problems. i have 33s on my truck ive seen guys with 35s 37s on stock suspension with no problems.
__________________
90 f250 4x4 5-speed 351w headman LT's 33x12.5 coopers CHEVROLET-Cheap Hardly Efficient Virually Runs On Luck Every Time
  #3 (permalink)
Old 06-24-2009, 07:02 PM
1966Tbird's Avatar
1966Tbird 1966Tbird is offline
1966Tbird is starting off with a positive reputation.
it depends what kind of axles you have a dana 60 will handle about 40in tires and not complain at all a 44 will handle 33in tires with no complaints a 8.8in rear will handle around 35in tires and not complain
not saying this is the limit but if you put 37s on your truck with a ttb dana 44 front end you'll probably be fine unless you offroad then you can count on breaking stuff i wouldn't run more than 35s on a ttb d44 front end and that's just if they are mud terrains if they are boggers figure 33s
__________________
89 F-150 leveling kit 33x12.5 BFG All-Terrains, Trick Flow Fast as Cast Heads, Comp Cams Gold Roller Rockers, Edelbrock RPM Air Gap Intake, Trick Fuel 750 Mechanical Secondary Carb, MSD E-Curve Distributor, Comp Cams 280hr Roller Cam, Comp Cams Roller Lifters, Comp Cams Valve Springs, Trick Flow Pushrods, DSS Main Girdle, ARP Bolts, Cometic Gaskets, Forged Pistons, 125 Shot of Nitrous, AOD, 3500 TCI Stall Converter, Lentech Street Terminator Valvebody, 4.56 Gears, Flowtech Headers, 2.5in Exhaust
  #4 (permalink)
Old 06-25-2009, 01:27 AM
Prozon's Avatar
Prozon Prozon is online now
1988 Ford F-350
Prozon is gaining momentum as a positive member of FTE.
I don't think you will have any problems running a 33. I know lots of people that run 35's with Dana44's and it works just fine. I'm running 37's with a Dana60 and its good aswell.
And that sack of potatoes comparison is quite possibly the most insane thing I have ever heard. I mean for me, I could do it all day, but for a mere man? That isn't even close to a good comparison.
__________________
1988 Ford F-350 460ci EFI
37" Super Swampers - Warn Winch
F-350 Planning Thread
  #5 (permalink)
Old 06-25-2009, 09:50 AM
hav24wheel's Avatar
hav24wheel hav24wheel is online now
hav24wheel is gaining momentum as a positive member of FTE.
It does provide more leverage on things,but if a 35 is the biggest your going to go you should be just fine with a 3/4 ton pickup..
__________________
my supermotors page http://www.supermotors.net/users/hav24wheel
78,85,92 Ford
Just bought a 94 F-150
  #6 (permalink)
Old 06-25-2009, 12:20 PM
Ok thank you guys, I appriceate all of the information
  #7 (permalink)
Old 06-25-2009, 12:27 PM
rivrrunner's Avatar
rivrrunner rivrrunner is offline
rivrrunner is starting off with a positive reputation.
35's with 4 inch lift/level kit....211k one set of ball joints...less mpg...they suck in the snow...but I like the way she looks
__________________
Brian
E 99 F350 CC LB SRW 4X4...6637/Pete's,CCV,DFA CCK,HPX,FPR , 17*HPOP,Zoodad,TruCool4739-1,Warn hubs,35'S, 4" lift,5" SP, 4 pod "A" pillar, shift kit, ITP OBA, DP-GS,NS,S,HI,40 T, Dcel, 60T, 80 E, 120 R, 140 AGG, PAA # 49
  #8 (permalink)
Old 06-25-2009, 07:00 PM
Prozon's Avatar
1988 Ford F-350
Quote:
...none of that was a complete sentence.
What was that supposed to mean?
__________________
  #9 (permalink)
Old 06-26-2009, 04:33 AM
rivrrunner's Avatar
translation.....if you run 265's or 285's you will get better mileage and better traction in Snow........copy that?
__________________
Brian
  #10 (permalink)
Old 06-26-2009, 02:50 PM
TheTinian's Avatar
TheTinian TheTinian is offline
TheTinian is gaining momentum as a positive member of FTE.
Im runnin 36's on a stock (as far as suspension) f150 and Ive been fine.
I dont understand the potatoe thing.....
The only thing youll notice if you go too big for your gears is a little bit loss of power and less MPG.
__________________
99 F150 Under the knife again. SAS, 1tons with 17.5 "'s of lift with 44's.
77 F250 For Sale
2001 F250 7.3 lariat 4x4.
  #11 (permalink)
Old 06-26-2009, 03:12 PM
Prozon's Avatar
1988 Ford F-350
265 or 285? I assume you are referring to the tire size. But if your using metric you need the second number. Its not a height specificly, its a ratio.
(265x75) which is like a 31? And (285x75) which is, what a 33?
As for the snow traction, I think that has more to do with your tire tread and how much frame your dragging. I've run 33's and i've run 37's in the snow. And the only difference in tire size was that I wasn't dragging around as much axle..
I think the F-250 would do just fine aswell. I've seen stock F-250's run bigger than that and not have much trouble.
I guess the potatoe thing wasn't thought out that well. I suppose the stress on your arms would be equal to the stress on the truck with bigger tires. Which, I completely disagree with.
I think that upgrading to 37's actually HELPED my gas mileage. I was cruising with high RPM's at 50mph with my 33's. Its much lower now that i've got the 37's. But for the most part it probably does reduce it.
__________________
Tags
04 , 1990 , 33s , 350 , 4x4 , biggest , f140 , f250 , f350 , fit , ford , largest , size , stock , tire , tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
