02-26-2001, 12:22 AM
two piece driveshaft
I have a Rug OD in my 79 F150 w/ a one piece driveline. The driveline shop said it was oversized and had a "speedlimit" as far as how many RPM's it would go before haveing problems... if your not low geared and or driveing really fast, you should be fine. I did find that it has a bigger sized U-joint than my 76 F100 that has a 2-piece driveline. I swapped out the rear gears from that truck to my 79 and then found I had to put the 79's pinion yoke onto my new rear carrier to match the bigger U-joint on my one piece driveline. You could have your two piece shortened.
BBT
