Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-24-2009, 10:44 AM
KennethKvittum KennethKvittum is offline
KennethKvittum is starting off with a positive reputation.
stuck horn & no cruise
2001 F-150 , horn was sounding with out touching pad and finally stuck on one day in parking lot, no cruise control since this time, was instructed by a FORD tech, that there are some contacts under the airbag cover, that could be bent down , does any one have an idea,i thinkg it is the clock spring, and where could i find an exploded view of the airbag unit.
  #2 (permalink)
Old 06-24-2009, 10:57 AM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
Clockspring sounds like a good guess to me. As far as an exploded view your local Ford parts department should be able to print one out for you, actual Ford manual would be best.
__________________
In automotive since 1973, Ford from 1992 to 2006
ex-Ford dealership employee
  #3 (permalink)
Old 06-24-2009, 06:11 PM
Still having hard time get owner of truck to go with me on this, would rather take the work of a ford tech,( Off The Record ) so i could not get a local dealer to show me a diagram of the airbag, does anyone know where i can find a working diagram of the airbag ,drivers side , to see what makes it tick.
  #4 (permalink)
Old 07-02-2009, 11:27 AM
1ATony's Avatar
1ATony 1ATony is offline
PREMIUM SPONSOR
1ATony has a good reputation on FTE. 1ATony has a good reputation on FTE.
I don't have a exploded view of the air bag section to post,but we do have a new clock spring for your application if you need one.
Here's a link to it with details about them.Hope this helps yah.
Ford F-150 Clock Spring
__________________
Tony
1A Auto Parts
1-866-403-3393
Click Here To Check Out Our Ford Truck Parts
  #5 (permalink)
Old 07-04-2009, 02:22 PM
SMok SMok is offline
SMok is starting off with a positive reputation.
Disconnect your cruise control servo and inspect the connector. I have seen brake fluid seep through the master cylinder swith and make its way all the way to the servo. It can then melt the connector at the servo. If your wondering why this would affect your horn, the ground for the horn goes through the servo.
  #6 (permalink)
Old 07-04-2009, 04:24 PM
ncranchero's Avatar
ncranchero ncranchero is online now
ncranchero is gaining momentum as a positive member of FTE.
To continue along the line SMok is taking. MAKE SURE the cruise switch recall has been done! If the switch is leaking the recall can take care of the switch and associated wiring, including the servo connector.
http://www.ford-trucks.com/recalls/r.../y-2001/t-6445
__________________
________________________________
"Information is valued and appreciated...Attitude is not!"
Steve,
'98 F150 Super Cab 4x4 SOLD, '99 Mustang 35th,
'02 Sport Trac 4x4, '01 Sport Trac Job 2 donor vehicle
'08 E250 Super Duty, No more Ranchero
Tags
04 , airbag , clockspring , control , cruise , duty , exploded , f150 , ford , heritage , horn , servo , stuck , super , truck , view
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
