Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-24-2009, 06:47 AM
foul1 foul1 is offline
foul1 is starting off with a positive reputation.
Air only blows on defrost???
Im assuming I have a baffel stuck? Worked on all the settings a week ago now that its 97deg out it only blow the cold air on the damn windshield. Anyone else have this happen? Hard to get to to fix?
  #2 (permalink)
Old 06-24-2009, 07:24 AM
ingman ingman is offline
ingman is starting off with a positive reputation.
I belive your right about the baffel. It could be a vacum issue. Just a thought.
I'm not a mechanic. Good luck.
__________________
2003, f350, cc, swb, afe progaurd 7, and 4" dimond eye turbo back.(lost the cat)
Former 97, F250, cc, swb (may she rest in peace) and OBS lover.
  #3 (permalink)
Old 06-24-2009, 08:02 AM
69cj 69cj is offline
69cj has a good reputation on FTE. 69cj has a good reputation on FTE.
Vacum leak or a faulty vacum pump will cause it to default to the defrost position also.
__________________
"05 F-250, 6.0, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, Magnefine p.s. filter, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
173rd Abn.
  #4 (permalink)
Old 06-24-2009, 08:11 AM
02PSD4ME's Avatar
02PSD4ME 02PSD4ME is offline
02PSD4ME is starting off with a positive reputation.
Quote:
Had the same thing happen to mine, it was the vavum pump.
__________________
2007 Dodge RAM, 4x4, 5.7L HEMI
2003 Ford Expidition, 5.4L, Eddie Bauer
2006 F-350 Super Duty, Lariat, 6.0L PSD, Crew Cab, FX4, 4x4, LWB, 3.73 LS, 20" wheels LEMON
PURCHASED BACK BY FORD! on 8/28/07.
1999 Toyota Tacoma 4x4, 2.7L 5sp TOWING MONSTER :-) (NO Frame Rust)
  #5 (permalink)
Old 06-24-2009, 09:14 AM
Ya no change this am tried heat too, was hopeing. Where would I vocate the vacume pump or is this somthing I can fix?
  #6 (permalink)
Old 06-24-2009, 11:55 AM
eddiedebb's Avatar
eddiedebb eddiedebb is offline
eddiedebb is starting off with a positive reputation.
The vacume pump is on the passenger side fender well.
__________________
03 F250 Lariat Super Duty FX4 6.0 PSD Auto
73 F100 Ranger 390 Auto
68 Cougar 302 Auto
68 F100 Sidestep 390 Auto
63 F100 Shortbed 351 manual
62 Falcon Ranchero 170 manual
  #7 (permalink)
Old 06-24-2009, 08:27 PM
claycomotrucks1991's Avatar
claycomotrucks1991 claycomotrucks1991 is offline
claycomotrucks1991 is starting off with a positive reputation.
Could be 4X4 vacuum regulator.
  #8 (permalink)
Old 06-25-2009, 01:56 PM
adambomb's Avatar
adambomb adambomb is offline
2005 Ford F-350
adambomb is gaining momentum as a positive member of FTE. adambomb is gaining momentum as a positive member of FTE.
try pushing the cab resurculation button on the A/C and see if the air comes out the vents or defrost?
__________________
2005 F350 6.0L Lariat FX4 Crew Cab Long Bed
*Industrial Injection Hybrid Turbo*90hp DDP Injectors*SCT X3*ARP Studs/Stock Gaskets*Banks Techni-Cooler*FASS Fuel System*AFE Intake*4" MBRP Turbo Back Exhaust*DieselTech1.com EGR*AutoMeter PhantomII Boost/Pyro/Trans Gauges*2.5" ICON Suspension*35" Xtreme AT's*18" KMC Monsters*AMP Research Steps*Pioneer AVIC N3 Nav-Rear Camera-iPod*
  #9 (permalink)
Old 06-25-2009, 06:33 PM
4x4 works fine (or it would still be at job site lol) NONE of the settings change the outcome, any combination......just defrost.
  #10 (permalink)
Old 06-25-2009, 06:51 PM
SuperBlue's Avatar
SuperBlue SuperBlue is offline
SuperBlue is starting off with a positive reputation.
Blend door stuck maybe?
__________________
2006 Ford F250XLT V10 4x4 CC LB 4.10's
95 Bronco XLT
  #11 (permalink)
Old 06-25-2009, 06:56 PM
How would u determine its the vacum pump? I would assume this would be the easy fix as oposed to taking the dash apart for the bafels or doors?
  #12 (permalink)
Old 06-25-2009, 07:27 PM
SuperBlue's Avatar
http://www.ford-trucks.com/forums/86...c-problem.html
Here's a link with some info and another link for the blend door fix.
http://www.ford-trucks.com/forums/85...-door-fix.html
good luck
__________________
95 Bronco XLT
  #13 (permalink)
Old 06-29-2009, 12:54 PM
rrrrick's Avatar
rrrrick rrrrick is offline
rrrrick is starting off with a positive reputation.
mine did that , was only a loose electrical connection on the vacuum pump. I unplugged it and plugged it back in and it has been working fine since.
  #14 (permalink)
Old 06-29-2009, 03:00 PM
12ozd 12ozd is offline
mmmmm...beeer
12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE. 12ozd has a great reputation on FTE.
Low/no vacuum will cause the htr. & a /c to default to defrost only.
Vacuum pump failure and vacuum line leaks are a common problem.
The vacuum pump is on the right (pass.) side fender.
Make sure you have power to the pump, if not check fuse.
If you have power,disconnect vacuum line and feel for vacuum.(hear pump run)
If no vacuum, replace pump. If you feel vacuum, then there is a leak.
Most common area for leak is vacuum hoses to; and front hubs (hence question about 4x4 earlier).
If pump is good, and no leaks,time to go inside the dash (doubtful).
  #15 (permalink)
Old 06-29-2009, 08:16 PM
Thats covering the bases! THANKYOU Oasis says selinoids have beed replaced twice for 4x4. Will get into it when I get a chance. Ill post the outcome for others to get info. Thanks again
Tags
2005 , 250 , 97 , ac , air , blows , conditioning , defrost , dodge , f350 , ford , powerstroke , pump , ram , stuck , vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
