Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
  #31 (permalink)
Old 08-03-2009, 01:27 PM
Beachbumcook's Avatar
Beachbumcook Beachbumcook is offline
Got Diesel?
Beachbumcook has a great reputation on FTE. Beachbumcook has a great reputation on FTE. Beachbumcook has a great reputation on FTE. Beachbumcook has a great reputation on FTE. Beachbumcook has a great reputation on FTE.
Here is the box top showing the new Ford/Motorcraft part number for the Pulse Vacuum Hub Solenoid Valve.
Part #: 7C3Z-9H465-A
I paid $48.25 which was the preferred customer price at my local Ford dealer.
It took 10 minutes (maybe less) to remove the old valve and install the new one. There is 1 electrical connection, 2 vacuum lines and 2 screws that hold it on... bingo... I now have 4WD and my AC blows out the front vents and not the defrosters!!!
I saved paying 1 hour of labor... but it was so easy to fix, I just had to do it myself... and so can you!!!
__________________
03 Excursion 6.0L PSD
Magnafine P/S Fluid Filter
Racor By-Pass Oil Filter System
Dieselsite Coolant Filter
Bilstein Shocks/Rancho Steering Stabilizer
Fumoto Oil Drain Valve
BriteBox Headlight Module
Marinco AC Block Heater Plug
24" Wiper Blades
Window Screen - Radiator Bug Shield
Pioneer Airware XM Radio
  #32 (permalink)
Old 10-29-2009, 09:22 PM
jmaskew's Avatar
jmaskew jmaskew is offline
jmaskew is gaining momentum as a positive member of FTE. jmaskew is gaining momentum as a positive member of FTE.
Just the thread I was looking for... has anyone had their Vacuum Pump vibrate like it wants to jump out of the engine compartment? Mine has been doing this intermittently for the past week or two. Its a very loud buzzing noise. Is there a way to take it apart and fix it (wanted to ask before I tear it apart...lol). Thank you.
__________________
^Camping at ZION NP, Utah^
Jonathan
2004 F250 PSD SB King Ranch 4x4:Build Date: 01/23/2004
Dieselsite Coolant Bypass Filter, High Idle Mod
Fumoto Oil Drain Valve, Harpoon Mod, Zoodad
Isspro 40 PSI Boost, Water Temp, Oil Temp and Trans Temp
  #33 (permalink)
Old 10-29-2009, 11:39 PM
Got Diesel?
Quote:
Mine just sounds like a compressor and then shuts off... some would say it is a buzzing sound... that's normal (or it has for 6 years on mine).
__________________
24" Wiper Blades
Tags
2005 , 250 , 97 , ac , air , blows , conditioning , defrost , dodge , f350 , ford , powerstroke , pump , ram , stuck , vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
