Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-23-2009, 03:52 PM
maddog2004's Avatar
maddog2004 maddog2004 is offline
maddog2004 is starting off with a positive reputation.
starting a 460
I rebuilt a 460 and I want to b sure it runs before I install it.How do I wire the coil or distributor to get it to fire? do I have to use the box (brain)? ty
  #2 (permalink)
Old 06-24-2009, 10:47 PM
maddog2004's Avatar
When I try to turn the motor over it cranks real slow like if the timing is to adv. or to much compression.When I pull the plugs it turns over no prob.This is what I did,Bought a used 83 460 and put new head gaskets,comp cam(valve lift .530 tappet lift 280),lifters,comp valve springs n seals,new timing set.I used rocker shims to adj pre load for the lifters because of higher lobe cam.Is it from exh valves not opening soon enough? Help pls.
  #3 (permalink)
Old 06-25-2009, 12:39 AM
mark a.'s Avatar
mark a. mark a. is offline
mark a. is gaining momentum as a positive member of FTE. mark a. is gaining momentum as a positive member of FTE.
Are you sure the dizzy is in right ? Good ground ?
__________________
'79 F250 13" lift 42" Super Swampers
  #4 (permalink)
Old 06-25-2009, 06:35 AM
maddog2004's Avatar
sorry,what is a dizzy? distributor? yes tdc! I used a good heavy set of jump cables.
  #5 (permalink)
Old 06-25-2009, 03:18 PM
maddog2004's Avatar
Do you think my valve timing could be off?
  #6 (permalink)
Old 06-25-2009, 06:47 PM
rikard rikard is offline
rikard is starting off with a positive reputation.
Back in the day when I had a high compression (12 to 1)engine I had to install a switch to cut the power to the coil. To start I would engage the starter and then flipt he switch for the ignition.
Try cutting the power to the coil and see if it turns faster. If it doesn't improve it could be the valve timing.
regards
rikard
__________________
Present-1995 Black F150 SC XLT 300 5 Spd
Past-1994 Red F150 SB XL 300 5 Spd
1983 Red F150 SB XL 302 AOD
1962 USPS 2.5 ton stepvan converted camper
223 3 speed DRW
1956 Red F100 Ma Bell uility bed 223 3 Spd
  #7 (permalink)
Old 06-25-2009, 07:12 PM
maddog2004's Avatar
Quote:
Originally Posted by maddog2004 View Post
sorry,what is a dizzy? distributor? yes tdc.I used a good heavy set of jump cables.
I connected battery with correct cables and it turned over plenty fast. Thanks. Going to swap motors this weekend.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
