My friend and I got talking about my truck and he told me the bus company he works for is just throwing out there old internatinal navistar bus turbos...
He said there are ore built ones and used ones just gettng tossed in favor of new ones
Get them, especially if they are throwing them in the trash. If they are t444e's they are 7.3's the Dt466 is a march different motor so I don't know if that one will work.
From what I just got through seeing in a quickie research effort, they are more than likely for the DT466 or DT466E engine. Still, if you can verify it, that would be good to know for sure.
Is the van turbo bigger to the eye?... also would the turbo off the bigger engine work?
Yes, somewhat. Easiest way is to look at the exhaust housing. The outlets are totally different because the vans have no wastegate like ours do. Have a look -- van outlet on the left, truck outlet on the right:
Or you can look at the housing where it connects to the collector. Van turbo says "1.15 A/R", truck says ".84 A/R".
Clay... there is no simple answer to your question.
But.... do I need? no....
... do I want? yes....
... can afford a ready to install rebuilt unit? no...
... am I willing to make a long term investment into a unit needing rebuilding at a VERY low price? perhaps, but that depends on how low "VERY low" is.
