Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-23-2009, 01:03 PM
tored1971 tored1971 is offline
tored1971 is starting off with a positive reputation.
Question Front brake job on 2002 E150
Hi all,
I am planning to replace the front rotors and pads on my 2002 E150 conversion van and have some questions.
1. The new drilled and slotted rotors came without the wheel studs installed, what is the best way to install them? (note to others, DO NOT buy from brakeplanet.com).
2. The rotors also did not come with inner and outer wheel bearings. Should I reuse the ones on the van or buy a new set?
Any tips or web site suggestions that might help me do this job would be GREATLY appreciated.
Thank You, Phil
  #2 (permalink)
Old 06-23-2009, 04:24 PM
blichty blichty is offline
blichty is starting off with a positive reputation.
1. Push studs through rotor and stack some washers on it. Use an impact gun with an open acorn lugnut to seat it. Maybe not the right way, but I have never had a problem.
2. If your old bearings are in good shape you can reuse them. However they aren't much $$$ so it may be worth the peace of mind for new ones. Which ever you choose make sure you pack them with good high temp grease.
Brian
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
