Go Back   Ford Truck Enthusiasts Forums > General > Garage and Workshop
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Garage and Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Is F-150 Still King?
  #1 (permalink)
Old 06-23-2009, 10:06 AM
alchymist's Avatar
alchymist alchymist is offline
"Mifflin Clay"
2008 Ford F-350
alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE. alchymist has a great reputation on FTE.
Pulling fence posts
Perhaps a little off topic, but:
I have a fence to tear down, and need a way to remove the posts. These posts are 4-5 inches in diameter, and from what I can find out, are hydraulically driven into clay soil about 2-3 feet. Even after all the rain we've had, they are rock solid. We tied pulling them with a chain on a scoop on the front of a farm tractor to no avail. Would lift the rear of the tractor off the ground. Even broke one chain.
Several that needed to come out at any cost we broke off - they break off at ground level, and don't push sideways at all. I swear they are screwed to bed rock! We tried pushing them back and fort from several sides with the tractor, they will not budge. So, any ideas? (No, I'm not gonna dig them out).
Personally, I carry a gun because I’m too young to die and too old to take an ass whoopin’.”
__________________
TRITON V10 - THE BEST KEPT SECRET -
(But word is getting out).
'08 F350 Scab SRW V10 w/ 4:10
07 Gulfstream Prarie Schooner
'05 Escape
' Passed the exam today! I am now a licensed instigator!
  #2 (permalink)
Old 06-23-2009, 02:40 PM
mitchntx's Avatar
mitchntx mitchntx is offline
mitchntx is starting off with a positive reputation.
Gonna be hard to describe but.
Back on the farm we used to take a 4x4 that was about 6" taller than the hitch on the tractor.
We would lean the 4x4 against the post to be removed with the top of the 4x4 about hitch high. So the botoom was about 6 inches or so away from the post at ground level.
We would wrap a heavy log chain around the base of the fence post several times and then run up the post and between the leaning 4x4 and fence post. (hard to visualize, I know ... even harder to describe).
Then hook the other end to the tractor and drive straight away.
As the chain pulled tight, it would try and stand the 4x4 up thus pulling striaght up on the fence post with as much force as the pulling tractor had, which is more that the leverage a bucket has.
If the ground is soft, you can use cribbing to keep the 4x4 from burying itself.
HTH
__________________
96 CMC Firebird
05 DL 1000 V-Strom
07 F250 Lariat 4x4 SD
  #3 (permalink)
Old 06-23-2009, 03:03 PM
FarmForward's Avatar
FarmForward FarmForward is online now
One after 909...
FarmForward has much to be proud of FarmForward has much to be proud of FarmForward has much to be proud of FarmForward has much to be proud of FarmForward has much to be proud of FarmForward has much to be proud of FarmForward has much to be proud of FarmForward has much to be proud of FarmForward has much to be proud of
I've used that method as well... what it does is use the 4x4 post as a fulcrum to leverage the fencepost out of the ground. It usually works pretty well, although I've managed to break off some posts doing it this way, but that may be due to rotting posts or over-enthusiasm on my part.
I take it that simply sawing them off at ground level is not a viable option?
__________________
The American Farmer Feeds The World
FarmForward
  #4 (permalink)
Old 06-23-2009, 03:44 PM
alchymist's Avatar
"Mifflin Clay"
2008 Ford F-350
Yeah, I know the angled 4X4 routine, used it to pull other fencing without problems. Wouldn't even budge these posts with that method. (Managed to splinter a couple of 4 X 4's & a 6" round post that way). These posts are really in there. Sawing them off is an option, but not a good one, as 1) I'd like to reuse the posts, and 2) couldn't plow where the posts are. All else fails, I'll dig down 6" or so and saw them off. Just thought someone might have a solution.
Thanks for the suggestions, though, keep them coming!
"The world is a dangerous place to live, not because of the people who are evil, but because of the people who don't do anything about it." Albert Einstein
__________________
'05 Escape
  #5 (permalink)
Old 06-24-2009, 12:05 AM
mudmaker's Avatar
mudmaker mudmaker is offline
2002 Ford F-350
mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE. mudmaker has a good reputation on FTE.
Get a bigger tractor!
__________________
Marc
2002 F350 SRW CC LB 4X4, PSD, 6637, CCV, Pretty much Stock
2002 Excursion Limited 4X4, PSD, 6637, CCV, Gauges, superchip(for now)
  #6 (permalink)
Old 06-24-2009, 12:18 AM
workinman workinman is offline
workinman is starting off with a positive reputation.
How about jetting around them to loosen them up ? I've used a pressure washer to bore holes for piles.
just a thought / good luck.
jeff
  #7 (permalink)
Old 06-24-2009, 04:09 AM
alchymist's Avatar
"Mifflin Clay"
2008 Ford F-350
That's what I love about FTE....someone's always go an idea...I wouldn't have thought of that one...now all I have to do is get my hands on a pressure washer, and give it a try...
"I think the best possible social program is a job." Ronald Reagan
__________________
'05 Escape
  #8 (permalink)
Old 06-24-2009, 11:27 PM
Homemade's Avatar
Homemade Homemade is offline
Homemade is starting off with a positive reputation.
If all else fails cut them off a foot above ground then try splitting them and removing that way.
__________________
1986 F250HD 4X4 4speed 460
1972 F250 C6 360 motor dead
1967 Mercury comet Rebuilding
2006 Ford Fusion DD
  #9 (permalink)
Old 06-25-2009, 12:19 AM
Chaosracing Chaosracing is offline
Chaosracing is gaining momentum as a positive member of FTE.
I say backhoe and dig them out. When they are hyrdro hammered into the ground, they are in there better than if the hole was dug and concrete poured around them. Thats why old bridge builders used to use wood poles and pile drive them into the ground.
If you do wind up cutting them off, I would go deeper than 6". I can guarentee if you cut them at 6", you will still hit them with a plow.
__________________
2002 Ford F250 4x4 V10<-FORD's best kept secret.
1947 Ford 1 Ton
2001 Sport Trac (Wife's vehicle)
Powered by Ford, Fueled by Madness
Support America and capitalism....BUY A FORD!!!!
  #10 (permalink)
Old 06-28-2009, 09:32 PM
GLR GLR is offline
GLR is gaining momentum as a positive member of FTE. GLR is gaining momentum as a positive member of FTE.
If you want to re-use the posts and are going to plow the land, why not rent a mini back hoe- excavator and dig them out? You should only have to dig down a couple of feet on one side of the post.
__________________
54 F100, 78 F150, 86 F250, 70 F100 Member #5 Boy you ain't Right Club
  #11 (permalink)
Old 06-29-2009, 07:50 AM
jroehl jroehl is online now
jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of
Jackhammer around them, then pull them with a bucket and chain.
Jason
__________________
-1993 F250 XLT xcab LB 351 2wd E4OD 4.10 open (parked, tranny issues)
The government cannot give to anybody anything that the government does not first take from somebody else.
http://folding.extremeoverclocking.c...e.php?u=402948
  #12 (permalink)
Old 06-29-2009, 07:51 AM
alchymist's Avatar
"Mifflin Clay"
2008 Ford F-350
In a word .$$$$!. Talking 40-50 posts. Fence has been sitting there for a year because time and $. Will get the fence wire off it this month, then worry about the posts. Already have removed close to 1000 feet of fence so far. Fortunately most of those posts were not set as tight and were able to pull them with the truck. I'm guessing if I can't get my hands on a pressure washer to try, will probably cut off just below the surface, and make it lawn. Anyway, cost of the post vs cost of digging it out is a no win.
”Those who would give up essential liberty to purchase a little temporary safety deserve neither liberty nor safety” Benjamin Franklin
__________________
'05 Escape
  #13 (permalink)
Old 06-29-2009, 07:56 AM
fellro86's Avatar
fellro86 fellro86 is offline
fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE. fellro86 has a great reputation on FTE.
I'll try to scan and post a diagram of what a few have mentioned above about the fulcrum and such, actually had that as a project in Statics...the group that had the project did a demonstration with a pickup...
__________________
the workhorse:86 F250 4x4 6.9 Diesel 4-spd, 4.10 axles, holley red electric pump
the other workhorse 92 F350 2wd crew cab, 4.10 rear axle, 92 6bt Cummins, NV4500 with Gear Vendors overdrive
the project: 77 F250 Camper special 400 4 speed
Iowa Chapter leader
Come on down and join us in the Iowa chapter, or your own local chapter!!
  #14 (permalink)
Old 07-04-2009, 12:10 PM
lvmadsigntist lvmadsigntist is offline
lvmadsigntist is starting off with a positive reputation.
Used to remove billboard posts by bolting angle or wrapping a cahin around the post and lifting straight up with 2 4x4 Hi Jack jacks. Cranes and back hoes always seem to have a tendancy to skew a bit but that straight up motion usually broke em free.
Tags
fence , ford , jackhammer , mudmaker , nv4500 , posts , pulling , tips , triton , truck , v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
