Crank pulley questions, Roller 302 with V belts
Old 02-26-2013, 01:21 AM
67-F100's Avatar
67-F100
67-F100 is offline
finishing up on a gt40p roller 302 swap in a 56 f100 and just about done and ran into this problem.
do they make a thinner pulley?
right now it has a mustang style 50oz HB and v belt pulleys that were supposedly from this truck..
what car/truck would have a pulley that i need? and anyone have one?
Old 02-26-2013, 07:38 AM
baddad457's Avatar
baddad457
baddad457 is offline
Well if you were using pulleys from a 56 F100,(no small blocks back then, not until 1962) that was your first mistake. You need a set of pulleys for an "alternator only" accessory drive setup. The crank pulley from a 70's 351 (W, M or C) will have the sheeve that lines up with that waterpump pulley. But since you've spent money on that shiny waterpump, I'd suggest getting a set of shiny aftermarket pulleys instead.
Old 02-26-2013, 02:25 PM
Beanscoot's Avatar
Beanscoot
Beanscoot is offline
Some junkyards have bins of random pulleys. Try to find such a place, bring your measuring tape and verniers and start digging.
Old 02-26-2013, 04:42 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
I think that water pump pulley may be your problem; it looks too deep. See if a v-belt pump pulley from another small block will work.
Old 02-27-2013, 12:37 AM
Beanscoot's Avatar
Beanscoot
Pulleys
If you don't need the double pulley it makes a better looking installation to get singles.
kyle19895.0
03-24-2015 11:54 PM
hav24wheel
08-25-2014 12:56 PM
pipman76
09-05-2009 05:43 PM
whitie's
04-27-2007 09:40 AM
Jag Red 54
06-28-2005 09:08 AM
Quick Reply: Crank pulley questions, Roller 302 with V belts
