Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-23-2009, 08:28 AM
donaldderby donaldderby is offline
donaldderby is starting off with a positive reputation.
85 e150 stalls when stopped
Ok guys please bear with me as i suck at using the serch but could any one tell me why me 85 e150 300 inline 6 with c6 trans runs and drives great but when i stop or sit still it will shut of thanks ahead of time.
__________________
RIP: 1987 f250hd 4x4 "blue" converted from 5.8l to 6.9l diesel c6 to np 435 bw1356 to np205 twinstick 86 front end.
1985 e150 cargo van "sway" 300 inline 6 )Carberated) c6 ford 9" rear transgo stage 2 shift kit
  #2 (permalink)
Old 06-23-2009, 10:11 AM
spikedog's Avatar
spikedog spikedog is offline
spikedog is gaining momentum as a positive member of FTE.
Help me out here - carb or fuel injected. I can't remember when carbs got replaced - mid-80's?
__________________
“If a tie is like kissing your sister, losing is like kissing your grandmother with her teeth out.”
- George Brett -
  #3 (permalink)
Old 06-23-2009, 10:15 AM
Its carburated with the newer style ignition (like the 5.0 vics) duraspark i belive
__________________
  #4 (permalink)
Old 06-24-2009, 12:47 PM
spikedog's Avatar
Has it always done this or is the bad idle a new thing? Idle can be adjusted several ways on the carb - I'd start with the position of the idle fuel mixture screws. How far open are the 2 screws? Hopefully they are around 1.5 to 2 turns open.
__________________
- George Brett -
  #5 (permalink)
Old 06-25-2009, 03:25 PM
its done it as long as i and the previous owner had it i am going to replace all the vacum lines, rebuild the carb and change all external gaskets july fourth weekend so hopefully i'll be all set. thank you though
__________________
  #6 (permalink)
Old 06-27-2009, 12:37 AM
fixnair fixnair is offline
fixnair is gaining momentum as a positive member of FTE.
Does it start in park and then stall when you put it in drive?
If thats the case then you have a locked up torque converter.
__________________
2002 F350 7.3 Ltr. 6sp.DRW 170K miles, 13' service body W/2200 # Venco hoist, Air compressor,10KW welder/generator, Air Horns, ceiling mtd CB W/250W Amp, Exhaust brake, Aux. Idle Control and Vac. operated hot water control.
1952 F1 flathead Project Truck
(It's got eight cylinders and I use them all )
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
