Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Escape and Escape Hybrid
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-23-2009, 07:58 AM
Scndsin's Avatar
Scndsin Scndsin is offline
Du Nawt Seek Thuh Treasur
Scndsin is a splendid one to behold Scndsin is a splendid one to behold Scndsin is a splendid one to behold Scndsin is a splendid one to behold Scndsin is a splendid one to behold Scndsin is a splendid one to behold Scndsin is a splendid one to behold
03 Cranks, No Start, or Starts & Barely Runs
Didn't wish to hijack another thread, so begining my own.
Our 03 LX 2wd with 80k+ gave us its first real trouble ever this past week. After about 10 miles interstate + 5 miles downtown driving on a 98 degree day, the wife stopped at a store for about 5 min. She parked in a space that was about a 20-30 degree nose-down incline. Tank was 3/4 to 4/5ths full of Chevron 87.
Upon return from store, Escape would crank normaly & try to start, but wouldn't. After several tries, it would catch and barely run, but she couldn't get it in gear before stalling & dieing. After instructions from me on the phone to floor it while holding brake, she got it to move a few feet back & level, whereupon it stalled out again & would not start again. Tow truck was called. After about 20 min of waiting, she gave it a try. Bingo! Started, idled normaly & made the remainder of the 20 mile trip home fine. Once home, it started fine repeatedly.
I hooked up my INNOVA scanner and the first communication attempt failed. Re-seated plug, tried again, established comm & promptly came back no codes in either KOEO or KOER, WTH??? All that piss-poor running & nothing recorded???
At any rate, the filter is original as far as I know & is on my list to change. The IAC is viginal & will get opened up for cleaning. My question for all that have had this happen is, was yours hot or on an incline? The day this happened, the heat index was over 100. Sounds like vapor-lock to me. Where do the fuel lines run? I've never had the reason to trace their path.
Anyway would really like to explore this.
__________________
David
94 F-150 XLT 5.8/E4OD SuperCab, 2WD
  #2 (permalink)
Old 06-24-2009, 12:19 AM
sfcwoodret sfcwoodret is offline
sfcwoodret is starting off with a positive reputation.
Sounds like some water was in your tank from some previous fillup(s) and worked it's way into your fuel line by the incline at park. Just a thought.
__________________
2006 Ranger XLT
2007 Ford Escape XLT
2007 Ford Mustang Premium
  #3 (permalink)
Old 06-24-2009, 12:49 AM
scott91370 scott91370 is offline
scott91370 is starting off with a positive reputation.
I didn't see it right off but there is another thread with a little info. The computer won't throw a code on this for some reason. Most people think it's IAC. Mine will do it, but only in warm/hot weather. I may pull the IAC and clean it to see. Search through the other threads and you'll get a little more info (wish I could have found it).
  #4 (permalink)
Old 06-30-2009, 11:14 PM
Trublufords Trublufords is offline
Trublufords is starting off with a positive reputation.
Unplug mass air next time and see if it runs fine now-Can't run it with it unplugged forever But anything on the sensor wire will not let it hardly run----Fly wings found on wire causes truck to be towed and and a hard bump on road while towing will knock whatever was on wire off and sucked into intake leaving NOTHING to be found. LOL Blue
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
