Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 06-23-2009, 12:53 AM
Blue Fox 4.6 Blue Fox 4.6 is offline
Blue Fox 4.6 is starting off with a positive reputation.
Cool Crapy running bronco 2
ok to start off the bronco was burn under the hood the wirin burt. so i put a harness on it an a ECM. but u can start it up an it will run fine but it will slow down a cut off, u can tap the gas an it will run fine an so on till it worms up thin it will stop. but u start to go down the road an its like its diein out u can mash it to the floor an it will pick up an go fine but thin start to die out agin but if u hold the gas still an not move it, it will **** there an bog an bog thin outa no were it will puck up an run fine, 4 bout a mile or too thin do it agin, an it dont allways do it sometimes u can to to the store an it wont do it thin cumin back it wont cum up a hill till it snaps out its lil spell iv
replaced the
ECM with 2 ECMS
4 MAP sens
3 TPS sens
6 IACS
on my 3rd fuel pump, the 1st on it was the factory one an it just guit over night an the 2nd one die after 1 week an i just put one on it today
the gas smells like its been in there 4 a year lol i put 2.5 gallons of 110 in it today an drove that all out hopin that will help but that just got rid of the popin back in the intake
  #2 (permalink)
Old 06-23-2009, 04:05 AM
Jab'sBronco2 Jab'sBronco2 is offline
Jab'sBronco2 is starting off with a positive reputation.
Have you done a simple tune up?
Sounds like you are just over shooting the issue, it will run but slowly dies off correct?
here is what i would check.
Bad Fuel,try draining and starting fresh, also check the fuel filter, while your at it make sure the fuel pump is working strong.
Plugs,wires,cap,rotor
If everything checks out the maybe run a can of injector cleaner through, maybe you have a clog.
Reply when you can.
  #3 (permalink)
Old 06-23-2009, 09:13 AM
kernel-panic's Avatar
kernel-panic kernel-panic is offline
kernel-panic is starting off with a positive reputation.
What year is your BII? I'm wondering if your ignition module is bad. You need to check all the sensors and/or pull diagnostic codes as well. Plenty of into in the READ FIRST Tech Info section on this forum...
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #4 (permalink)
Old 06-23-2009, 11:01 AM
Cool
ok well i put a new fuel filter on it to i just 4 got to minchin it lol mybad,
but iv ran the gas out an put 110 racin gas in it an so far it ant helped but i only drove it like 20 miles
i ant put plugs wires an cap on it yet it just dont ack like them but i could b rong
can that module on the side of the distributer do this?
  #5 (permalink)
Old 06-24-2009, 03:41 AM
the module can do that, take it off and take it in to be tested.
at least inspect the cap / rotor i had a buddy who spent around $300.00 on misc parts for his B2 and still couldnt get it to run, and it turned out to be a hairline crack in the Distributer cap.
Good luck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
