Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1980 - 1986 F100, F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 06-28-2009, 07:46 PM
81-F-150-Explorer 81-F-150-Explorer is offline
1981 Ford F-150
81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE. 81-F-150-Explorer has a very good reputation on FTE.
Quote:
Originally Posted by flipklos View Post
Used a toggle switch on my 96 XL. Worked fine. never had a problom remembering to turn out the switch. Everytime I forgot the glow under the truck gave it away.
The circuit will ground through the hinge. Try it. Please, please, dont argue worthless info.
The hood Ground strap on a 1996 is apart of the right hinge itself. You will see the strap bridge the two pieces of the hinge together.
This is not the case for 1980-1986. (although you can use 1992-1996 hinges on a 1980-1986), the original 1980-1986 hinges does not have the built in ground strap and needs the seperate one.
Please don't give incorrect info...
This is the 1980-1986 Forum, 1992-1996 are different.
  #17 (permalink)
Old 06-28-2009, 09:50 PM
flipklos flipklos is offline
flipklos is starting off with a positive reputation.
Got an 85. Aint got no strap. Got a extendeble underhood light in it. It works!
  #18 (permalink)
Old 06-28-2009, 10:09 PM
1981 Ford F-150
You just said you had a 96 XL in the post before this last one.
Which is which? or do you have both a 1985, and a 1996?
  #19 (permalink)
Old 06-28-2009, 10:18 PM
I had a 96 without a factory hood light. I installed two. I put a toggle switch in it. Worked good.
I own an 85. It has the factory light in it. The groundstrap was thrown when I rebuilt the engine. Light still works.
  #20 (permalink)
Old 06-28-2009, 11:13 PM
1981 Ford F-150
Thanks for the clarification.
Why you would throw it away is beyond me though. What I say is correct, it won't ground through the hinges very well, if at all, and it's a loose connection. You can't argue that it's tight, otherwise it wouldn't pivot.
Removing it can also affect your radio antenna and reception, because it uses the hood as a ground plane. There was a reason why Ford put it there, and it wasn't just because they wanted to for no reason
Unless you replaced and have a right side 1992-1996 hinge on your truck,...
1992-1996 Hinge with Ground strap riveted on it.
1980-1986 Ground strap
Underhood Retractable Lamp. Working and Very Brightly lit. With it's ground hooked to that pesky ground strap.
  #21 (permalink)
Old 06-28-2009, 11:24 PM
first today's Avatar
first today first today is online now
first today has a good reputation on FTE. first today has a good reputation on FTE. first today has a good reputation on FTE.
I think you may have solved why my radio stations are weak. My light works on and off. I do not have that ground.
I have a 93 hinge out in my pasture. Would I do better with that hinge or get a strap.
EDIT - I just looked and I do have that strap. I am going to check the ground tomorrow.
__________________
Call me Kyle
_____________________________
  #22 (permalink)
Old 06-28-2009, 11:37 PM
1981 Ford F-150
Either one should work fine.
My original hinge was bent so I replaced it with the 1992-1996 one.
Less labor intensive to just get a strap though IMO. You wouldn't have to alighn the hood etc...
  #23 (permalink)
Old 07-04-2009, 02:12 AM
whatthencuz's Avatar
whatthencuz whatthencuz is offline
whatthencuz is starting off with a positive reputation.
where is the "switch" for the underhood light? how does it know when to turn on? I wanna put white led lights under the hood and I would like for them to turn on when I open the hood
  #24 (permalink)
Old 07-04-2009, 02:23 AM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Festus Hagen is gaining momentum as a positive member of FTE.
If you read the thread you find that it's a mercury switch inside the under hood light.
-Enjoy
fh : )_~
__________________
-= Improve Knowledge ... Share your's! =-
1986 F250 SuperCab Dually 4WD 6.9IDI T19 BW1345 D50TTB Sterling 10.25 3.55's
1991 F250 StdCab 2WD 7.3IDI ZF5 Sterling 10.25 4.10's
  #25 (permalink)
Old 07-04-2009, 02:41 AM
so is there a constant 12v going to the light?
  #26 (permalink)
Old 07-04-2009, 03:14 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a good reputation on FTE. ctubutis has a good reputation on FTE.
Quote:
Yes, via the light-green/yellow-stripe wire coming out of the firewall near the
brake master cylinder.
Tags
1984 , 2009 , bulb , explorer , f150 , f250 , firewall , ford , ground , hood , light , location , strap , turn , work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
